Latest: Kifi69
Overall: 17183
Online Now [409]:
Visitors: 408
Today: 40380
Total: 143589109
Forums › The Car › 206 Problems › ESP/ASR Issue
ESP/ASR Issue
-Kitsune-
PostPosted: Mon Feb 14, 2011 11:15 am Up
Hi,
So on the weekend I was looking around the steering column to see if I could get into the indicator controls etc.. Before I did I "shut down" my car and disconnected the battery, I also then re-connected my battery and did a BSI soft start etc once I was done, now my ESP/ASR is giving issues, it keeps giving me ASR/ESP not functioning, I've just reset it again now and still the same..
Help??
2006 206 GTi180, Red.
No pity. No mercy. No Regret
Big_Rich180
PostPosted: Mon Feb 14, 2011 11:16 am Up
ABS ring, ABS sensor, ABS wiring, could be anything get the codes read.
Antix
PostPosted: Mon Feb 14, 2011 11:25 am Up
Custom - Red Stars
Before you do anything else, take the car for a spin.
It could just need to reset itself.
The ESP/ASR 'fault' and ABS light on often occurs when on a dyno test too.
Big_Rich180
PostPosted: Mon Feb 14, 2011 11:27 am Up
Tis true argg, can take a min for it to realise its working again.
-Kitsune-
PostPosted: Mon Feb 14, 2011 2:09 pm Up
Hmm okay, thanks, shall give it a shot, too late for a drive now Smile
Antix
PostPosted: Mon Feb 14, 2011 2:13 pm Up
Custom - Red Stars
never too late for a drive in a 180 Wink Laughing
-Kitsune-
PostPosted: Mon Feb 14, 2011 3:01 pm Up
Hahaha! So so so true but I'm running low on fuel (below empty) and not in the mood to go fill her up..
PostPosted: Mon Feb 14, 2011 6:04 pm Up
-Kitsune- wrote:
Hi,
The ESP steering angle sensor is built in to the com2000 unit Wink
Have you knocked a plug loose on the back of the com unit OR tampered with the wiring?
-Kitsune-
PostPosted: Mon Feb 14, 2011 8:16 pm Up
MrBSI wrote:
-Kitsune- wrote:
Hi,
Embarassed Embarassed Ahem, yes.. Embarassed
I imagine it's the small plastic pin that sits on the right hand side of the steering wheel and is slotted into the grooves?
PostPosted: Tue Feb 15, 2011 4:03 am Up
-Kitsune- wrote:
MrBSI wrote:
-Kitsune- wrote:
Hi,
New com2000 units for these are very expensive due to the ESP & also are meant to be set up with PPS for the steering angle sensor after fitment.
PostPosted: Tue Feb 15, 2011 5:08 am Up
This was my problem when my steering wheel was'not straight when my wheels where aligned. Had it re-tracked and it was fine.
-Kitsune-
PostPosted: Tue Feb 15, 2011 10:46 am Up
Re-tracked by the dealer?
PostPosted: Tue Feb 15, 2011 11:51 am Up
No just the garage which had changed my tyres and got it wrong. The steering wheel must be absolutely straight when tracked. My steering wheel was at about a 25 degree angle off straight, when the front wheels were straight.
