Forums › The Car › 206 Talk › GTi Injectors |
Posted: Tue Feb 15, 2011 3:36 am |
are the 138 bhp and 180bhp injectors the same? i got a fault with injector 1 but don't know if there the same as a 180
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
Posted: Tue Feb 15, 2011 6:03 am |
Apprently the 180 injectors are different.
Posted: Tue Feb 15, 2011 8:29 am |
hmm , would 180 injectors work on a 138???
| *DEAD*206 Gti 138
Posted: Tue Feb 15, 2011 11:59 am |
Pointless unless you've got serious modifications.
Posted: Tue Feb 15, 2011 12:13 pm |
i don't want it for any power inprovments just a case of what i can get hold of cheapst
i dont bother with mods not my style id rather just buy a faster car.
i have my bikes for speed
| *DEAD*206 Gti 138
Posted: Tue Feb 15, 2011 12:25 pm |
180 injectors are bigger, im pretty sure. but dont take that as a biblical
| Originate, don't duplicate. | |
Posted: Tue Feb 15, 2011 12:27 pm |
leigh_boy wrote: |
i have my bikes for speed |
even if they physically fit you will need a remap to get the flow correct.
and not to mention you can't just fit 1 180 injector with 3 138 injector in line.
Posted: Tue Feb 15, 2011 12:36 pm |
ok to the remap didnt really cross my mind, and i wouldnt replace just 1 i would do the lot
| *DEAD*206 Gti 138
Posted: Tue Feb 15, 2011 12:53 pm |
Will physically fit but the flow rate will c**k things up.
Posted: Tue Oct 29, 2013 11:37 am |
bringing this thread up again...
what is the cc of 138 and 180 injectors?
| 206 1.6L 16V XT - RIP
206 GTi 138++
Koni Sport dampers, H&R springs, GTi180/RC rear axle and front ARB. Sparco strut bar, Yokohama AD08R tyres, Raceland 4-1 manifold, Remus backbox, Magnaflow sport cat, Catcams Fast Road cams, Unichip Q piggyback ECU, Pipercross VIS kit, Vibra Technics mount kit, 283mm Brembo Max front discs and rear discs, Ferodo DS2500 front & rear brake pads, Goodridge brake hoses, 307 23.8mm master cylinder, brake servo and calipers; Quaife LSD, AST adjustable top mounts and 206 WRC rear spoiler (just can't resist it).
Postpone / KIV / Coming soon: Mocal oil cooler kit.
Removed: Combrake top mounts. | |
Posted: Sun May 25, 2014 3:04 pm |
Bump
| 1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170 | |
Posted: Mon May 26, 2014 12:08 am |
GTI138
▪ Static rate to 3 bar, n-heptane unit [g / min.]: 141
▪ Resistance [Ohm]: 14.5
Part number: 1984 E2
GTI180
▪ Static rate to 3 bar, n-heptane unit [g / min.]: 187
Part number: 1984 F3
Found it out almost a month ago.
206 GTi 138++
Posted: Fri Feb 13, 2015 4:12 pm |
Edward wrote: |
Will physically fit but the flow rate will c**k things up. |
Yet to remap mine and the 180 injectors have been fine, no engine management lights or erratic jumping rev's.
Posted: Fri Feb 13, 2015 4:48 pm |
That doesn't mean everything is right.
Posted: Fri Feb 13, 2015 4:51 pm |
Very true, who would you recommend to remap when I get it booked in.
