Latest: Beduff1977
Overall: 17134
Online Now [1932]:
Visitors: 1931
Today: 94876
Total: 107755074
Forums › The Car › 206 Talk › Location Of Rev Sensor?
jonny_fulton03
PostPosted: Wed Feb 16, 2011 8:51 am Up
Hey people,
Just wondered if anybody knew where the rev sensor was located on a 1.4 lx 1999? Cheers. Joni
-RAJ-
PostPosted: Wed Feb 16, 2011 9:27 am Up
i think its on the gearbox somewhere
leigh_boy
PostPosted: Wed Feb 16, 2011 11:25 am Up
correct its on gear box its yellowy looking prbabbly black from road crap tho.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
perry081064
PostPosted: Wed Feb 16, 2011 11:49 am Up
is this usually the issue for the rev counter on the speedo not working then ?.
mines not working, but the dealer is just gonna change the speedo.
206 2.0 HDI
PostPosted: Wed Feb 16, 2011 11:55 am Up
9 out of 10 is the speedo problem, could be the needle is stuck somehow
PostPosted: Wed Feb 16, 2011 1:21 pm Up
Rev sensor? You mean crank sensor?
Or if the speedo has stopped working you might want to look at the speed sensor. Both are fitted to the gearbox.
jonny_fulton03
PostPosted: Wed Feb 16, 2011 1:34 pm Up
cheers guys. Al get the sensors off and give them some WD40. See if that works! Joni
I don't think that will help.
What's the problem?
PostPosted: Wed Feb 16, 2011 4:16 pm Up
Ed is right.
Speedo (mph) is the sensor on the gearbox, revs (rpm) takes it off the crankshaft position sensor.
If there is no rev-counter action, its unlikely the crank sensor is gone or else the engine would not
run very well if at all.
WD40 will definately not help any of the two sensors.
PostPosted: Wed Feb 16, 2011 5:12 pm Up
It wouldn't run full stop Laughing
leigh_boy
PostPosted: Sat Feb 19, 2011 3:19 am Up
rev sensor IS on the GEAR BOX but ye basicaly its a speedo sensor
*DEAD*206 Gti 138
PostPosted: Sat Feb 19, 2011 4:43 am Up
Speed sensor back of gearbox
Rev sensor (crank sensor) between gearbox and engine Basicly 
PostPosted: Sat Feb 19, 2011 3:27 pm Up
Nope.
Crankshaft position sensor works by detecting a magnet positioned on the flywheel and has nothing to do with gearbox. The ECU then works out revs from this, as well as which cylinder to spark next, ignition timing etc.
perry081064
PostPosted: Sat Feb 19, 2011 3:31 pm Up
.......so, at the end of the day, what is the main culprit when the rev counter doesnt work then ?
206 2.0 HDI
PostPosted: Sat Feb 19, 2011 3:34 pm Up
Dial? Maybe??
