Online Now [273]:
Visitors: 273
Today: 5521
Total: 143314524
Forums › The Car › 206 Problems › 99 206 high revving on own accord
cinders30
PostPosted: Thu Feb 17, 2011 9:19 am Up
Hi,
My car has started to rev high usually in stand still or changing in low gear, it then backs off when you take the clutch up and accelorate!! I have had the idle valve changed and it was okay for a couple of weeks but has now started again today. Any ideas please would much appreciate it as i rely on my car. Thanks.
Very Happy
pudmonkey
PostPosted: Thu Feb 17, 2011 9:24 am Up
Mine does this on occasion aswell, i gave the idle control valve a clean the last time but as with yours it happened again not long after. Anyway, i dont have a fix, just thought i would add my two pence worth!
giveitsomebar
PostPosted: Thu Feb 17, 2011 9:37 am Up
throttle position sensor ?
MrZiggerz
PostPosted: Thu Feb 17, 2011 9:39 am Up
Mine does this, but it only shoots to about 1500 - 2000. I always thought this was because my Clutch Release is busted.
cinders30
PostPosted: Thu Feb 17, 2011 10:48 am Up
It can go from 1500-3500 Sad
Very Happy
Lee180
PostPosted: Thu Feb 17, 2011 11:18 am Up
common fault tbh mate, i just turned the car of and back on again when it happened to 1.4 8v'er and it seemed to be fine.
Originate, don't duplicate.
jonny_fulton03
PostPosted: Thu Feb 17, 2011 12:56 pm Up
mine did this exact same thing. Also a 1999:-) to fix it i just disconnected the negative terminal for an hour, reconnected then it was fine and has bin since! Joni
PostPosted: Thu Feb 17, 2011 1:35 pm Up
Is the EML on?
Could be the MAF or MAP sensor.
Disconnecting the battery with reset the ECU to default.
