Posted: Mon Dec 20, 2010 9:32 am |
This is the second time now when I have gone to start my car in the cold and the heater refuses to run hot even when the engine gets to full temp. I was trying for 45 min to clear my screen this morning (frozen inside and out). I turned it off and started it many times when going in and out to get warm water and de-icer. I also tried fiddling with the nobs to see if the warm stuff would come out. Didn't go hot but when i came out of work a few hours later it was working fine.
Any ideas?
If I chop the plug off a hair dryer and wire it to my battery will it work as a temp fix?
Posted: Mon Dec 20, 2010 9:37 am |
| ...You don't like my opinion? Wait until you hear the ones I keep to myself...  | |
Posted: Mon Dec 20, 2010 9:40 am |
Its 240V in the UK, but I know what you mean
| 4.0 V8 S-Type Jaguar
Image removed due to size | |
Posted: Mon Dec 20, 2010 9:46 am |
namgaj wrote: |
Its 240V in the UK, but I know what you mean  |
Used to be it's now standardised to 230V +10% −6% As far as I'm aware..
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Posted: Mon Dec 20, 2010 10:07 am |
All i know is dont plug a power supply from a pc when its switched onto 110v into a uk soccket
| Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Posted: Mon Dec 20, 2010 10:09 am |
Danny224 wrote: |
All i know is dont plug a power supply from a pc when its switched onto 110v into a uk soccket  |
They dont last very long
Can anyone else smell burning
Posted: Mon Dec 20, 2010 10:16 am |
I didn't think about that It just came to my head. Advice on my problem wouldn't go a miss tho
Posted: Mon Dec 20, 2010 10:37 am |
Check your water level in header tank.... bleed the hoses at the heater for air locks..... get an engine cooling system flush.... alternatively... stick a garden hose up the heater pipes at the back of the engine with both hoses off... do both ways to make sure its not blocked.... remember to check antifreeze levels after
Posted: Mon Dec 20, 2010 10:39 am |
macj wrote: |
get an engine cooling system flush |
NON biological washer powder / liquid / dish washer tablets added to the header tank are ideal for this
It MUST be NON biological! ! !
Posted: Mon Dec 20, 2010 10:40 am |
MrBSI wrote: |
Danny224 wrote: |
Can anyone else smell burning  |
Ive done that and the pc was sitting on my leg. Scared the jizz out of me.
Posted: Mon Dec 20, 2010 11:22 am |
cheers macj. Do you think its down to a blockage rather than broken heater controls/bad connection then? Checked the water a few days ago and its got pleanty in it. Not sure why that would effect it. How does the heater bring in the hot air I am only familiar with how the cold intake work.
Posted: Mon Dec 20, 2010 12:25 pm |
Hot water goes to heater matrix makes a radiator warm.a fan behind this radiator blows the air.air gets warm when passed through then goes through ducts you select on heater panel.two lines from engine coolant system go to heater matrix.if upper one is as warm as the lower one(when engines warm)could be said heater matrix is ok.
| el camino. "Whether you think you can or you think you can't, you're right" Henry Ford. | |
Posted: Tue Dec 21, 2010 9:36 am |
I see now. Would have thought if the pipe is frozen then the engine would be overheating as well. I have about half a bottle of anti-freeze in it couldn't fit any more
Posted: Tue Dec 21, 2010 11:07 am |
macj wrote: |
Check your water level in header tank.... bleed the hoses at the heater for air locks..... get an engine cooling system flush.... alternatively... stick a garden hose up the heater pipes at the back of the engine with both hoses off... do both ways to make sure its not blocked.... remember to check antifreeze levels after |
this is what i was going to say.
| Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k. | |
Posted: Tue Dec 21, 2010 11:08 am |
Rob2859 wrote: |
I see now. Would have thought if the pipe is frozen then the engine would be overheating as well. I have about half a bottle of anti-freeze in it couldn't fit any more  |
you need to drain the rad and put a min of 2 litres mate
| Mark
