Latest: tbafonso
Overall: 17130
Online Now [266]:
Visitors: 265
Today: 37491
Total: 104619244
Forums › The Car › 206 Problems › steam but no leak
steam but no leak
Rusky
PostPosted: Fri Feb 18, 2011 9:08 am Up
been bleeding cooling system all seems goo went for test run and 2 thing have happened temp gauge seems to have mind of its ow and when i got home opened bonnet noticed small amount of steam from rad area but there are no leaks
im liking this little toy
PostPosted: Fri Feb 18, 2011 9:12 am Up
Air lock.
PostPosted: Fri Feb 18, 2011 9:34 am Up
If the radiator is wet or damp it will steam as it heats up.
Rusky
PostPosted: Fri Feb 18, 2011 9:45 am Up
think i sorted airlock
