Posted: Sat Feb 19, 2011 11:05 am |
I have a 206 gti180 and when I pull away the whole car vibrates. The slower I pull away the more it does it. The clutch does not slip but it sounds like it is going to stall. Very awkward to drive in traffic. Any ideas? Or is this common with these cars? Thanks
| | ![](images/spacer.gif) |
Posted: Sat Feb 19, 2011 11:12 am |
Common clutch shake just add a bit more revs and you will be fine.
Posted: Sat Feb 19, 2011 11:29 am |
DMF?
| Peugeot 206 GTI HDI Black | |
Posted: Sat Feb 19, 2011 12:38 pm |
had same fault with mine, got really bad. New clutch kit and flywheel skim needed
Posted: Sat Feb 19, 2011 2:10 pm |
ive got the same problem, but only when i use the clutch, any possibility its a loose nut or something under the bonnet?
Posted: Sat Feb 19, 2011 2:23 pm |
nah its a clutch fault, every 180 has this fault at some stage.
Posted: Sat Feb 19, 2011 4:24 pm |
ive just got a regular 1.4 model ![Sad Sad](images/smiles/icon_sad.gif)
Posted: Sat Feb 19, 2011 4:39 pm |
more than likely be the clutch, hard to say with out driving it.
