Online Now [477]:
Visitors: 476
Today: 5151
Total: 104955554
Forums › The Car › 206 Talk › 180 engine on gti gearbox
giveitsomebar
PostPosted: Sat Feb 19, 2011 3:19 pm Up
as above will the 180 engine go on against a gti gearbox? also are the driveshafts the same thickness?
Smile
PostPosted: Sat Feb 19, 2011 3:34 pm Up
same driving shaft and same gearbox(different ratio)
giveitsomebar
sweeet thank you! Smile
D4NTP
PostPosted: Sat Feb 19, 2011 4:44 pm Up
I thought they were different, being 6speed.
PostPosted: Sat Feb 19, 2011 4:47 pm Up
the 180 isnt six speed only 5 i think the box is similar but the ratios and the gear linkages are different has cable gearlinkages on the 180
D4NTP
PostPosted: Sat Feb 19, 2011 4:55 pm Up
so what exactly is the point if a '180' it has variable valve timing...... is that it? pointless car! why would you want a 180 gearbox anyway?
giveitsomebar
PostPosted: Sat Feb 19, 2011 5:12 pm Up
you could spend a fortune getting an extra 50bhp from a 138 engine but you can buy a 180 engine for £450 my plan is a 180 engine into a gti shell its WIP though
PostPosted: Sat Feb 19, 2011 5:14 pm Up
GTi180's only have about 160bhp
giveitsomebar
PostPosted: Sat Feb 19, 2011 5:17 pm Up
well a decent cam for a 138 is £400 quid just seems the right thing to do
PostPosted: Sat Feb 19, 2011 5:20 pm Up
Good look with the rewiring, thats all i can say.
giveitsomebar
PostPosted: Sat Feb 19, 2011 5:38 pm Up
ahhh its going to run omex my dads a electriction so ill leave it to him! Very Happy
PostPosted: Sun Feb 20, 2011 4:29 am Up
What does it having VVT got to do with gearboxes?
Andy180
PostPosted: Sun Feb 20, 2011 5:00 am Up
what a stupid comment.
GTI 180
Schumi
PostPosted: Mon Feb 21, 2011 3:05 am Up
You cant install lower travers without changing gear selection system. GTI selection bars hiting gti180 exhaust manifold. So you can use your gearbox but you have to change selection system bar to cable.
2005 206 RC RED
PostPosted: Mon Feb 21, 2011 4:23 am Up
exactly Rolling Eyes
there's a loooot more to the 180 than just the vvt i drove both when i bought mine years ago and there's no comparison.
im sure this will open the usual whinge that there's not much difference but iv never heard anyone with a 180 wish they had just bought a 138
i assume they need a gearbox and cant find one but have found a 180 one cheap
