Online Now [47]:
Visitors: 46
Today: 28366
Total: 105036750
Forums › The Car › 206 Problems › Wiring Loom
Wiring Loom
Marky234
PostPosted: Tue Feb 22, 2011 8:51 am Up
Im building a tarmac rally/track car.
but considering ive removed most of the electricals i was wondering how hard it would be to build my own custom loom.
am i right in thinking aslongs as the engine ecu has a 12v feed then that will operate without the BSI.
if thats the case then i will remove the BSI as the electric windows, airbags, radio and sunroof have all been removed. the cars never had ABS so thats no problem.
i would have to build a new fuse board for the lights and fuel pump i know im just not sure if i can get rid of the BSI unit and still have the car operate as normal.
Any help would be great cheers
1.6 XSi Stage Rally Car Build In Progress
PostPosted: Tue Feb 22, 2011 8:54 am Up
How much weight you gonna save building your own loom?
If you really wanted couldnt you just remove the now not needed wires from the original loom?
Marky234
PostPosted: Tue Feb 22, 2011 8:58 am Up
ive removed the wires its just where the roll cage fits is where the BSI mounts. i know it doesnt sound like much but ive got to move the BSI to the passenger side but with the very few plugs that are in it i might aswell get rid if i can
PostPosted: Tue Feb 22, 2011 11:41 am Up
Does the engine ECU not run through the BSI?
