Online Now [529]:
Visitors: 528
Today: 7642
Total: 106201875
Forums › The Car › 206 Problems › Urgent electrical fault
Go to page 1, 2, 3, 4  Next
gavlar83
PostPosted: Mon Feb 21, 2011 2:15 pm Up
hi im new to the forums,im needing help with an electrical problem with my 206,i was fitting my new stereo an 2 wires tocuhed,now the car wont start,it turns but wont spark,also the wipers dont work the indicators are not working and the side lights cum on wihtout me turning them on but high beam wont work an the sidelights only go off when i take the key out,iv tried the fuses under the bonnet and the drivers side,i really need help i have work wednesday and need my car sorted asap,any help would b massively apreciated,thankyou
is learning slowly but surely Smile
Signature Removed - Please See Your PM's
PostPosted: Mon Feb 21, 2011 2:17 pm Up
What year is your 206?
You have either:
Blown a fuse.
Crashed the BSI software.
Fried the BSI.
PostPosted: Mon Feb 21, 2011 2:18 pm Up
You should ALWAYS ALWAYS disconnect the battery prior to messing with electrics. You wanna hope that you haven't fried the BSI!
Check EVERY fuse in the drivers fuse box, and EVERY fuse in the engine fuse box. Disconnect the battery correctly before removing the fuses.
If the fuses are fine, then I'm afraid its multimeter and wire tracing time
PostPosted: Mon Feb 21, 2011 2:19 pm Up
More like bend over & get the Vaseline out time Wink
Fingers crossed it aint a fried BSI unit
PostPosted: Mon Feb 21, 2011 2:22 pm Up
I'd wire trace first before shelling out about £700 Laughing
PostPosted: Mon Feb 21, 2011 2:24 pm Up
Peugeot planet time Wink Laughing
gavlar83
PostPosted: Mon Feb 21, 2011 2:31 pm Up
thanx for the info the year is 2004,and how do i find the bsi?and what do u mean by trace the wires?im know how to fit a stereo but thats about it,lol thanx
PostPosted: Mon Feb 21, 2011 2:32 pm Up
Obviously you don't otherwise this problem wouldn't have happened.
Try rebooting the BSI [click my sig], and check all the fuses
PostPosted: Mon Feb 21, 2011 2:34 pm Up
Shut the BSI down CORRECTLY.
Check ALL the fuses.
Boot it back up & cross your fingers.
A multiplexed 206 doesnt like people fiddling with its electrical systems while there live, if your lucky its gonna be a simple / cheap fix plus a lesson learned Wink
Big_Rich180
It sounds like a fuse, mine did the same thing one night while driving down a dark road lol
gavlar83
PostPosted: Mon Feb 21, 2011 2:36 pm Up
i have checked the fuses in under the bonnet and drivers side is there anymore?
paulrushton
PostPosted: Mon Feb 21, 2011 2:38 pm Up
Have a look in your handbook and see if any of the systems not working are on the same fuse.
Peugeot 206 GTI HDI Black
PostPosted: Mon Feb 21, 2011 2:39 pm Up
Nope, & you shouldnt be playing with any of the fues if the battery is still connected as you can damage the BSI unit if you havent already.
BSI needs to be shut down correctly before you do any more damage.
PostPosted: Mon Feb 21, 2011 2:44 pm Up
Seabook wrote:
is your car plex or pre-plexed?
04 plate is gonna be multiplexed Wink
PostPosted: Mon Feb 21, 2011 2:45 pm Up
ya, didn't see that post Laughing
Page 1 of 4
