Latest: Beduff1977
Overall: 17134
Online Now [197]:
Visitors: 196
Today: 65899
Total: 107378167
Forums › The Car › 206 Problems › Misfiring + Fault Codes
Go to page Previous  1, 2
richpowell91
PostPosted: Sun Feb 27, 2011 4:53 pm Up
Not sure if this will help anyone else but will update a bit.
Picked up my new coil pack yesterday morning, took me 30 seconds to fit it and try it, and hey presto no change Mad
Read somewhere on the internet that one way of testing which cylinder is misfiring is to drip some water on the exhaust manifold branches then which ever branch the water doesnt evapourate off you have a problem with that cylinder.
The result was number 4 cylinder (closest to the camshaft sproket) taking much longer to to get rid of the water. Then i remembered reading on autodata that a common fault was that number 4 injector would fail due to water leaking onto it. So plan for tomorrow is to switch number 1 and 4 injectors around and then if the misfire follows the injector have a dodgey injector. If not i know i have a problem related to number 4 cylinder to investigate further.
Page 2 of 2
