Posted: Thu Feb 24, 2011 5:59 pm |
Can somebody point me in the right direction of a cambelt for a GTi180
thanks in advance
| Originate, don't duplicate. | |
Posted: Thu Feb 24, 2011 6:11 pm |
Frodingham Motor Spares in town or AE Cooks matey
Posted: Thu Feb 24, 2011 6:12 pm |
Peugeot service desk?
| Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi | |
Posted: Thu Feb 24, 2011 6:18 pm |
you want to buy the kit or you want a garage to do it for u?
Posted: Thu Feb 24, 2011 6:25 pm |
either or mate.
Posted: Thu Feb 24, 2011 6:31 pm |
if you are going to diy then get the dayco, gates or peugeot cambelt kit.
if you let the garage do it, it would properly cost around 300 as yours is 180GTi
you might want to do the waterpump as well.
Posted: Fri Feb 25, 2011 1:59 am |
Seabook wrote: |
you might want to do the waterpump as well. |
Deffinatly do the water pump too! as i have recently found out. If the pump fails, thats will probably cause the cambelt to fail. And a water pump is about £25.
So well worth doing
Posted: Fri Feb 25, 2011 10:38 am |
rob_1990 wrote: |
Seabook wrote: |
So well worth doing |
£25 FOR A GTI 180 WATER PUMP????? you making this your self. First off i would all ways only fit a genuine peugeot water pump on these gti 180's which is around £80 with vat and a aftermarket one is round £40 and you dont get the back housing part with this one like the genuine ones so you have to spilt the water pump in half to fit new after market one and can leak very easy
The gti 180 can be very hard to time up if you do NOT have the proper timing tool and can quickly cause alot damage to engine due to the floating crack ( no wood duff key in crank pully )
If a garage never done one of these i would not use them to risky job to guess how to do it.
Kyle
| 206 Gti 180 Cat-camshafts 804's, Cat cams CTPE 002 exhaust vernier pully, RS tuning remap, Cat back janspeed exhaust, K@N Typhoon induction kit- heat wrapped, Exhaust manifold heat wrapped, Goodridge brake flexi's poly bushs in rear lateral arms, blue led speedo convertion, 50mm Eibach sport line springs, ......
180 Doctor
Hemwoods Gti180 / Pug specialist | |
Posted: Fri Feb 25, 2011 10:57 am |
gti180boy wrote: |
Euro Car Parts do water pumps with the housing.
Posted: Fri Feb 25, 2011 11:04 am |
Seabook wrote: |
It was a Dayco timing belt kit that failed on my 206 GTi after 5k miles.
Don't recommend.
Posted: Fri Feb 25, 2011 11:35 am |
CD-vRS wrote: |
Seabook wrote: |
Don't recommend. |
really?
i though dayco is one of the manufactorer for peugeot oem stuff lol
Posted: Fri Feb 25, 2011 12:40 pm |
Might not have been fitted properly.
Posted: Fri Feb 25, 2011 12:49 pm |
sorry to crash this thread but gti180boy fitted my cam belt, i had spoken to lots of people about a 180 cam belt and everyone said use genuine parts! I was quoted 500+ from all garages and after watching gti180boy fit mine i can see why!! Its no easy two minute job it took him 4hours to change my cambelt and waterpump and he has done nearly 20 i think so my advise would be to use genuine parts and get someone whos done one before to do it!!
| Gti 180
Team 209 PEUGEOT 206 GTI 180 BLACK 922 | |
Posted: Fri Feb 25, 2011 1:01 pm |
What people need to realise is that although a cambelt box will say Peugeot on it, the belt inside will say Gates on it. The aftermarket part will say Gates on it too. They are the same part. Just because it doesn't come from the Peugeot dealer doesn't mean it's a different part.
The same OE suppliers also manufacture the parts for the aftermarket. As long as you stick with the big brands and don't go for the cheapest parts you'll be getting identical parts or parts of the same quality.
Posted: Fri Feb 25, 2011 1:44 pm |
Seabook wrote: |
CD-vRS wrote: |
Seabook wrote: |
Don't recommend. |
really?
i though dayco is one of the manufactorer for peugeot oem stuff lol |
The tensioner was sent to Italy for testing if I remember correctly.
Found to be at fault & the belt slipped.
