Latest: Stu-mill
Overall: 17131
Online Now [561]:
Visitors: 560
Today: 52140
Total: 104860981
Forums › The Car › 206 Talk › WindScreen Removal
WindScreen Removal
bellevuespares
PostPosted: Thu Feb 24, 2011 6:33 pm Up
Hiya guys, Have any of you removed a 206 screen before? if so, what design/make tool did you use and was it difficult to take out with breaking?
Thought id ask before i start salvaging them.
Cheers Smile
Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes!
PostPosted: Thu Feb 24, 2011 6:37 pm Up
Someone on here has the removal tools for a sale at a cheap price, Check the for sale section mate and im sure he could let you know how to do it
bellevuespares
PostPosted: Thu Feb 24, 2011 6:39 pm Up
Will check it out now, just wanted to know if im better off with the blades or wire, or will i need both?
Not worried about price as long as it does the job with ease and breakages.
PostPosted: Thu Feb 24, 2011 6:41 pm Up
Well ive heard that wires are the best but the wire itself is shaped like a blade if you get me, any tool which can be used to remove though gives more options which is good
Ill have a look for you
PostPosted: Thu Feb 24, 2011 6:44 pm Up
Here you are
Link
bellevuespares
PostPosted: Thu Feb 24, 2011 6:45 pm Up
Ive found his thread, he wants 80 quid, il see what i can get New.......
kieron
PostPosted: Fri Feb 25, 2011 3:03 am Up
you will pay around £70 for the lifters, the wire is around £10 and handles around £30
they tool i have forsale is what the call a wet knife you fill it up with a solution and as you are cutting it runs the fluid down the back of the blade so its easy to get out
you cannot buy it in this country and last time i looked it was over £200
i was doing windscreens for years day in day out and still they broke!
206s at the bottom the bonded glue line is around 2 inchs up so you have to wire the bottom out and if you dont watch what you are doing you can cut the dashand a pillers with the wire
and some cars like mk3 mondeo,s astra vectra and alot other have what they call encapluated windscreen and only be used oned and will tear when taken out
Account suspended
