Latest: Stu-mill
Overall: 17131
Online Now [574]:
Visitors: 573
Today: 42973
Total: 104851816
Forums › The Car › 206 Talk › break noise...
break noise...
dopey
PostPosted: Fri Feb 25, 2011 1:59 am Up
I had my break pads and sicks replaved on last mot in begining of september only recently when i break I can hear a sharp hissing noise.
Any one know what it could be? I have done a search on breals dqeuaking but didnt come up with anything.
Thanks in advance
PostPosted: Fri Feb 25, 2011 2:40 am Up
The noise is probably the disc's & pads bedding in. Should stop soon.
Ape
PostPosted: Fri Feb 25, 2011 2:47 am Up
When you press the brake, do you get a short hiss from the passenger side? If so then that's normal, if it's continually hissing there's a problem. How does the pedal feel?
Sounds like something to do with a servo / vacuum if it's constant hissing.
If it's a scraping noise, then it would be worth cleaning the pads with a wire brush and see if it helps.
Bedding brakes in takes 15minutes after they've been fitted, not 3months +
macj
PostPosted: Fri Feb 25, 2011 3:33 am Up
Have dealt with this twice now on a car thats had new pads.....
Ape
PostPosted: Fri Feb 25, 2011 3:51 am Up
Isn't that more of a scraping than hissing though? I assume it can only be through incorrectly bedding them in and glazing them over?
dopey
PostPosted: Fri Feb 25, 2011 4:08 am Up
Its a hissing just when i break from say 20 to stop not when i just press breaks. Brakes feel fine and it sounds like coming from n/s/r
Ape
PostPosted: Fri Feb 25, 2011 4:38 am Up
[quote="Ape"]If it's a scraping noise, then it would be worth cleaning the pads with a wire brush and see if it helps.
quote]
