Latest: lio94
Overall: 17181
Online Now [188]:
Visitors: 187
Today: 102664
Total: 140740634
Forums › The Car › Solved 206 Problems › New key.
New key.
NICKST
PostPosted: Fri Feb 25, 2011 4:37 pm Up
Had a new blade cut as the old one was wearing down. It will unlock/lock the car by remote and manually. Will turn ignition barrel but want start the car it's the original chip that's all ways been used just a new blade. Any ideas?
PostPosted: Fri Feb 25, 2011 4:41 pm Up
Have you swapped the trasponder chip over
NICKST
PostPosted: Fri Feb 25, 2011 4:47 pm Up
Yes if I put the old blade back in it works fine.
PostPosted: Fri Feb 25, 2011 4:50 pm Up
So you all you have done is a new blade cut not a full new key?
The transponder chip hasnt moved has it when you swapped the blade over
NICKST
PostPosted: Fri Feb 25, 2011 4:53 pm Up
That's right just a new blade. The chip did fall out of the case. The new blade will unlock the doors and lock them. It will also turn the ignition barrel just want start the car.
PostPosted: Fri Feb 25, 2011 4:56 pm Up
The transponder chip is either:
Missing
OR
Not in the correct place inside the key
The transponder chip is NOT part of the circuit board! ! !
Uz
PostPosted: Fri Feb 25, 2011 4:57 pm Up
You have to transfer your chip from your old key to your new key otherwise the car will not start.
NICKST
PostPosted: Fri Feb 25, 2011 4:58 pm Up
Missing
OR
If it wastnt in the correct place in the key it the buttons wouldn't line up to unlock/lock it would that.
PostPosted: Fri Feb 25, 2011 5:00 pm Up
Open the key up, fit the transponder chip correctly & the car will start.
NICKST
PostPosted: Fri Feb 25, 2011 5:02 pm Up
There is now new key just a new blade.
PostPosted: Fri Feb 25, 2011 5:03 pm Up
How did the chip fall out then?
If its just the blade you dont need to open the keyfob.
NICKST
PostPosted: Fri Feb 25, 2011 5:04 pm Up
Thanks mr bsi will try it now the didn't realise the transponder chip wasn't on the circuit board.
NICKST
PostPosted: Fri Feb 25, 2011 5:06 pm Up
Thanks mr bsi will try it now the didn't realise the transponder chip wasn't on the circuit board. It was the circuit board that fell out.
Thanks.
NICKST
PostPosted: Fri Feb 25, 2011 5:22 pm Up
Working now thanks for the help Smile
PostPosted: Fri Feb 25, 2011 5:28 pm Up
Was it the transponder chip?
