Posted: Sat Feb 26, 2011 7:59 am |
Just been cleaning my engine bay and after i had finished i went to start the car and drive off but before i did when the car was sitting idle it was struggling to hold the 1000rpm it usually does and juddered a lot (felt like it was going to stall but didn't) And then noticed the 'amber engine light' was flasing!! Daren't drive off until i know what it is!? Any ideas??
| 206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out! | |
Posted: Sat Feb 26, 2011 8:00 am |
| MutilateTheDead wrote: |
| Just been cleaning my engine bay |
What with? ? ?
Posted: Sat Feb 26, 2011 8:04 am |
Just a cloth, it is wet where i am though, and some water did trickle in!
Posted: Sat Feb 26, 2011 8:10 am |
| Just a cloth, it is wet where i am though, and some water did trickle in! |
Where did the water trickle in?
There's plenty of electrical bits under the bonnet that wont be happy getting wet
Posted: Sat Feb 26, 2011 8:13 am |
Straight down the middle, didn't think it was on much, will it sort itself out over time
Posted: Sat Feb 26, 2011 8:18 am |
cant hurt to let it fully dry out and see if it goes away did it drip on any sensors?
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Sat Feb 26, 2011 8:27 am |
I wouldn't even know here they are haha, i know not to f**k about with the engine again when its wet!
Posted: Sat Feb 26, 2011 9:04 am |
The light is no longer flashing but it is still on constantly!
Posted: Sat Feb 26, 2011 10:15 am |
Got bored so polished and waxed the beast, left bonnet open facing VERY strong wind to try and dry the engine bay out a little and it worked :) Cheers MrrNoName
Posted: Sat Feb 26, 2011 1:25 pm |
The light flashing means its detected a misfire, on constant will just be telling you its stored codes.
Has the light now turned off?
| If in doubt, drop a cog and put your foot down  | |
Posted: Sat Feb 26, 2011 7:52 pm |
Yeah its turned off now, i think the engine did misire because water trickled into the engine bay, feels fine now Thanks guys
