Latest: Beduff1977
Overall: 17134
Online Now [661]:
Visitors: 660
Today: 240520
Total: 110094739
Forums › The Car › 206 Problems › trolley jacking points
xrblue
PostPosted: Sun Feb 27, 2011 3:15 am Up
Hi guys
Can anyone tell me where the trolley jack points are on my 2004 fever? I need to replace a track rod end.
Ta
2004 1.4i 206
usher
PostPosted: Sun Feb 27, 2011 3:24 am Up
I would use the sub frame area the sils will crush with a trolley jack
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Sun Feb 27, 2011 3:53 am Up
You need a chunky piece of timber between jack head and car. You put the jack under the box sections that run under the side of the car.
giveitsomebar
PostPosted: Sun Feb 27, 2011 5:02 am Up
where the wishbones meet the subframe
spike_202
PostPosted: Sun Feb 27, 2011 7:35 am Up
Ditto I use a bit of skerting board also
**spike's project**
TEAM:+200bhp
PostPosted: Sun Feb 27, 2011 8:45 am Up
On low car you can't get the trolley jack under the subframe.
usher
PostPosted: Sun Feb 27, 2011 9:33 am Up
I'm having trouble with the front end as my scisor jack has packed up so got a trolley jack and from previous exp the sills aint strong
project thread WIP
garage
FAQ
206 gti firedance
xrblue
PostPosted: Sun Feb 27, 2011 9:42 am Up
thanks for the replies, I should buy a work shop manual but I'm too tight Smile
2004 1.4i 206
Jamie1337
PostPosted: Sun Feb 27, 2011 10:40 am Up
Trade Rating: +37
drive onto bits of wood?
Light Right Foot FTW!
PostPosted: Sun Feb 27, 2011 10:46 am Up
I use house bricks! Laughing But I use the subframe too, is that a good idea?
PostPosted: Sun Feb 27, 2011 11:36 am Up
Very interested in this one..
As I have trouble understanding what exactly is meant by sills and sub-frame,
would it be possible someone sorts out a pic with arrows on it?
I would like to use a trolley jack and stands.
Jamie1337
PostPosted: Sun Feb 27, 2011 4:11 pm Up
Trade Rating: +37
sills are were you jack up using scissor jack. rear axle/wishbone/subframe are decent enough points for a trolley jack
PostPosted: Sun Feb 27, 2011 4:20 pm Up
Wishbones aren't designed to be loaded along their length.
