Latest: Beduff1977
Overall: 17134
Online Now [606]:
Visitors: 605
Today: 35473
Total: 108851484
Forums › The Car › 206 Problems › Juddering, Wierd one
joshack
PostPosted: Tue Mar 01, 2011 5:27 pm Up
Hello,
My 206 5 door judders badly when i let off the revs and put the clutch down or just let off the revs. It stops when i put my foot back down on the revs. But it also stops when i put my foot on the brake, Ive got a feeling its the front left wheel thats making the noise. But cannot grasp onto what it is.
drive:206 lx diesel
PostPosted: Tue Mar 01, 2011 5:48 pm Up
I take it the car is moving when it judders? To get some clarity, when you let off the power you get a judder, when you accelerate or brake you don't get the judder. Is the judder coming through the steering, the pedal or just the car in general? What noise are you on about? A judder is what you feel, a noise is what you hear.
joshack
PostPosted: Tue Mar 01, 2011 6:03 pm Up
Its a juddering noise. And yeah what you say is correct, when i let off power there is the juddering noise and car judders too. And when i accelerate or brake there is no judder or noise. And just the car in general.
Cheers
drive:206 lx diesel
PostPosted: Tue Mar 01, 2011 6:13 pm Up
If you were getting feedback through the steering then it would more than likely be on the wheel.
I would look at your fuel system. Not worked on a 206 diesel, but quite possibly the fuel distribution pump badly worn and not stopping the flow of fuel to the cylinder when you release the accelerator. You might even have an air leak in the fuel line or a crack in an injector. Definately sounds mechanical rather than suspension or steering if it is making the whole car judder and you are not feeling anything through the steering wheel.
sp5flys
PostPosted: Wed Mar 02, 2011 2:44 am Up
mine does the same when its rolling in 1st it sounds rough and judder does it judder when u brake ?
.. Peugeot 206 2.0 D turbo hdi ..
