Online Now [116]:
Visitors: 115
Today: 21833
Total: 138812289
Forums › The Car › 206 Problems › Running Temperature question - 1.6 HDi
unstabletable
PostPosted: Thu Mar 03, 2011 12:30 pm Up
Just wondering on a 1.6HDi, should the coolant temperature move about a bit?
Seems to take its time to get up to 80 (sometimes 5 miles), and sometimes goes back down to 75, or up to 84.
Suspected thermostat may be a bit funny, but the heater is blowing out warm air no problem.
Is it normal? Coolant level is about 1/2 way between max and min.
apjs87
PostPosted: Thu Mar 03, 2011 2:02 pm Up
That's all normal. No need to worry
No longer a 206 owner
Astra H sxi. 1.7Cdti
SDK206
PostPosted: Thu Mar 03, 2011 2:03 pm Up
I asked this question about my 2.0 hdi and yes its normal, it will flucuate a little but nothing to worry about for some reason they can take an age to warm up according to the gauge but if your getting warm air through the vents i wouldn't worry
If in doubt, drop a cog and put your foot down Smile
ma.langan
PostPosted: Thu Mar 03, 2011 2:09 pm Up
When I sit at meets or with friends my engine temp goes from 80 down to 45 and then the heater go cold = fail
Farmer T'aaron!
unstabletable
PostPosted: Thu Mar 03, 2011 2:49 pm Up
cheers guys, just needed clarity Smile
80 down to 45? epic.
