Latest: tebas93089
Overall: 17179
Online Now [219]:
Visitors: 218
Today: 12556
Total: 138532297
Forums › The Car › 206 Problems › its doing my nut in
its doing my nut in
black31
PostPosted: Sun Feb 13, 2011 5:35 pm Up
hi am hoping to get some help with a problem with our lasses 206 ,its had new drop links and bottom arms both sides the wheel bearings are fine but.....when you accelerate from a low speed there is aloud clunk only once until you brake fairly hard then there is another my first thought was engine mount so had a look and all seem ok pulled around by hand and bars =nothing ,handbrake hard on lots of revs to try pull away rocking up and down =nothing mmmmmmmmmmm maybe drive shafts empty carpark full lock both ways =nothing i am running out of ideas can anyone shed any light or pass on any thoughts that may help i would be really gratefull thanks in advance hope some one can help
m
stevedude
PostPosted: Sun Feb 13, 2011 6:22 pm Up
might be strut mount and bearings
Happydays
black31
PostPosted: Sun Feb 13, 2011 6:38 pm Up
thanks for reply but its not ive replaced one and do actually have the other to do but unfortunatlly it not
m
Mattie-RS
PostPosted: Sun Feb 13, 2011 6:50 pm Up
driveshaft
black31
PostPosted: Sun Feb 13, 2011 7:02 pm Up
it maybe but usually would make a noise when on full lock but its not ?????
m
black31
PostPosted: Tue Feb 15, 2011 5:06 pm Up
anyone else any ideas
m
black31
PostPosted: Thu Mar 03, 2011 11:11 pm Up
anyone else its still knocking away
m
NathanG
PostPosted: Fri Mar 04, 2011 4:34 am Up
How long ago did you change the droplinks. I changed mine 6 months ago and had to change the passenger side one again last week for the MOT, must have been a dodgy pair. Have you checked the bushes.
VorTechS
PostPosted: Fri Mar 04, 2011 4:38 am Up
Staff - Vortechs
Out of interest, is the clunk definately coming from the front?
It's not something like the drums/brakes sticking?
00budham00
PostPosted: Fri Mar 04, 2011 4:39 am Up
suspension mounts
D4NTP
PostPosted: Fri Mar 04, 2011 2:48 pm Up
I know you said you have checked the engine mounts but the fact it does it under acceleration and braking makes me think it's mount related
