![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › Rear hub help |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Sat Mar 05, 2011 10:41 am |
A while ago a local mechanic managed to strip one of the wheel bolt threads in the rear hub on my 206 GTI. Anyway manged to get hold of a replacement hub to swap it over. Question time now - is it a case of pop off cap in centre of hub, remove hub bolt (32mm?), pull hub off a replace?
Got a breaker bar for hub bolt, but heard its still a nightmare to remove, do i need hub puller to remove hub after bolt removed, and is hub nut reusable and how tight for hub nut.
Sorry about all the questions James
| | ![](images/spacer.gif) |
Posted: Sat Mar 05, 2011 4:25 pm |
Trade Rating: +13
You shouldn't need a breaker bar.
You will need the remove the disk, caliper and dust shield.
Halfords do a hub puller for £12
They usually fall apart when being removed, so you may need to split the inner of the bearing, or just tap it off (but it's a tight fit).
To refit I put it on with a ring spanner between the hub and hub nut, do the nut up to push the hub on.
Posted: Sun Mar 06, 2011 12:41 pm |
cheers fella.
| ![](themes/base/images/forums/otr.gif) |
