Latest: Puggingalong
Overall: 17129
Online Now [447]:
Visitors: 446
Today: 15384
Total: 101527447
Forums › The Car › 206 Talk › Throttle Cable..
Throttle Cable..
Surfer333
PostPosted: Mon May 23, 2011 7:49 am Up
Hi Folks,
The throttle cable...which ties into the Carb. Where / how many notches is it supposed to be, when it is located back with the metal clip?
I.e..how many notches should the metal clip be from the top part of stopper?
I have tried to find an answer but ...came up with diddly squat!
Cheers.
View user's profile Visit poster's website AIM Address MSN Messenger
furryhobnob
PostPosted: Mon May 23, 2011 7:51 am Up
On 206gti.net it says there should be 13 notches above your clip, I counted mine and it's exactly that
PostPosted: Mon May 23, 2011 7:57 am Up
Just pull it back till it pulls the throttle body open
Or in other words creates a slight resistance to being pulled open more
Surfer333
PostPosted: Mon May 23, 2011 8:33 am Up
Ok, I'll try it on that number. Many Thanks.
Cheers.
PostPosted: Mon May 23, 2011 10:48 am Up
Doing it that way would just be too easy though.
PostPosted: Mon May 23, 2011 3:54 pm Up
Surfer333 wrote:
Hi Folks,
Are you sure you should be even looking under the bonnet Wink
There should be a multipoint fuel injection system under there not a carb.
Surfer333
PostPosted: Tue May 24, 2011 3:17 pm Up
MrBSI wrote:
Surfer333 wrote:
Hi Folks,
Always get part wrong. DOH
Yes if that's what it is ....
Taa.
;-)l
