Latest: Beduff1977
Overall: 17134
Online Now [189]:
Visitors: 188
Today: 173847
Total: 108509964
Forums › The Car › 206 Talk › why is this plug loose?
bisphenol-a
PostPosted: Mon May 23, 2011 8:17 pm Up
And what is it
Its this maroon plug above the torx screw
Antknee
PostPosted: Mon May 23, 2011 9:07 pm Up
because its not plugged in by the looks of it?
abs06
PostPosted: Tue May 24, 2011 12:17 am Up
Check the other side
But seems like it may be ir indicator
Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14)
PostPosted: Tue May 24, 2011 12:18 am Up
Plug is the wrong colour & you can see the indicator is plugged in, look at the picture Wink
bisphenol-a
PostPosted: Tue May 24, 2011 12:43 am Up
all the lights.. indicators.. temperature readings are fine.
im just wondering what is that maroon plug meant for. it is quite wedged and i cant move it about. wanted to take the wire and see how far it could stretch to give me an idea where it came from.
but nah..
Jack4273
PostPosted: Tue May 24, 2011 12:59 am Up
thats a good question, cuz when i took my car apart there were 2 plugs not plugged into owt, so i would also like to know Razz
Clarion VZ409E 7 inch DVD motorised screen
Sony XMZ-R604 440 watts Channel Amplifier
Vibe Slick 12" 1200 watt Subwoofer
Pioneer TS-A6903i 6 x 9 3-way 350 watts
Raceland 4-2-1 Stainless Steel Manifold
Remapped Ecu
Wolfrace Street Hustle 17"
Very Happy
Click For Da WIP! 206info.co.uk/Garage/m...d=336.html
ukskater01
Could it be for frosted headlights? What year is yours?
Andy180+
PostPosted: Tue May 24, 2011 1:01 am Up
that plug is for the alarm switch on the bonnet catch mate
Abzynthe
PostPosted: Tue May 24, 2011 1:23 am Up
East Area Rep - Abzynthe
What He Said
bisphenol-a
PostPosted: Tue May 24, 2011 1:38 am Up
so where should it go?
what exactly is this alarm?
dumdum0910
PostPosted: Tue May 24, 2011 1:39 am Up
ive got 1 on my car but its dangling down near the floor.
Abzynthe
PostPosted: Tue May 24, 2011 1:42 am Up
there's a plug behind the grille near the bonnet catch
PostPosted: Tue May 24, 2011 2:29 am Up
Don't think it is.
Have it as well and bonnet switch works lovely.
Try opening the bonnet and seeing if you get message on the MFD.
Abzynthe
PostPosted: Tue May 24, 2011 2:31 am Up
That plug doesnt stop the bonnet opening, it just powers the bonnet alarm sensor.
Not all 206's have an alarm system fitted BUT because Peugeot use generic looms to keep costs down you may have extra plugs fitted that are not actually used due to your spec of car Wink
If you have a factory fitted anti theft alarm system then it will connect to the bonnet sensor on the bonnet catch, being an Australian spec car I doubt it will have one as the spec is pretty mean down under.
