Latest: Beduff1977
Overall: 17134
Online Now [1522]:
Visitors: 1521
Today: 235679
Total: 109802039
Forums › The Car › 206 Problems › Ticking under Dash
Ticking under Dash
CeeBee206
PostPosted: Mon Mar 07, 2011 6:42 pm Up
Hi , since I changed the multi function Relay that was flattening the Battery and causing non-starting, the car is running fine but has developed a constant ticking (like the sound indicators or wiper relays make) about 1 sec. apart and all the time the ignition is on. Sounds a bit like the second hand would make on a clock. Nothing seems to be operating that shouldn't but it is annoying. It seems to be coming from in between the steering column and the drivers door and somewhere down around the light switches.
Any ideas please ?
Cheers Maz. Cool
206 1.4 LX Full Leather.
Antknee
PostPosted: Mon Mar 07, 2011 6:54 pm Up
oh dear, sounds like that relay is actually a bomb Surprised
drunknmunky
PostPosted: Mon Mar 07, 2011 7:07 pm Up
he might be right you know id drive your car as far away as possible and run away from it and never go back Laughing
CeeBee206
PostPosted: Tue Mar 08, 2011 1:59 pm Up
Thanks for the two replies. Very helpful ! I'll try to be as helpful when I answer someone who's got a problem.
Cheers Maz. Evil or Very Mad Rolling Eyes
PostPosted: Tue Mar 08, 2011 2:02 pm Up
was it replaced with exactly the same type?
do you have a rear wiper? if not you sure its not turned on?
