Latest: tbafonso
Overall: 17130
Online Now [112]:
Visitors: 111
Today: 14812
Total: 102372261
Forums › The Car › 206 Talk › Worn Camshaft/HID Questions
PostPosted: Fri Mar 11, 2011 1:37 pm Up
Right ho peoples, i have two things to ask
1. I have a piper cam sat on my desk, but it has a few deep groves where it sits in the engine circular holders? Not on the lobes
Would this effect it in any way if i put it in?
2. I have H4 morettes and my outer dipped beam is also one of my main beam lenses, (twin filiment) would i need a Hi/Low HID set or would just a low be ok?
Ta muchly Very Happy
leigh_boy
PostPosted: Fri Mar 11, 2011 1:41 pm Up
pics may help , i don't know what car you have but if its a twin cam i wouldnt bother just putting one in with out the other as they ware ( spelling ) at the same rate.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
PostPosted: Fri Mar 11, 2011 1:42 pm Up
Its an 8 valve Wink
Will do mate
PostPosted: Fri Mar 11, 2011 2:10 pm Up
PostPosted: Fri Mar 11, 2011 2:12 pm Up
That cam is fit for the metal recyling skip.
What happened to the head it came from, bearing's would be well shagged Laughing
PostPosted: Fri Mar 11, 2011 2:16 pm Up
Would have thought youd need high/low for your type morettes. (also assuming high beam is needed for MOT and purely for vision it makes sense)
PostPosted: Fri Mar 11, 2011 2:52 pm Up
He run it out of oil
So its knackered? What would it run like with it in?
PostPosted: Fri Mar 11, 2011 2:57 pm Up
Those engine circular holders as you call them are where the camshaft bearings run inside the cylinder head.
It would still run, but not for very long before it shagged the bearings.
PostPosted: Fri Mar 11, 2011 4:09 pm Up
If you can feel the grooves it's past its best. Apart from anything you can see corrosion on it - not good.
PostPosted: Fri Mar 11, 2011 5:36 pm Up
just put the cam on ebay, i am pretty sure someone would buy it lol
PostPosted: Sat Mar 12, 2011 2:37 am Up
A scrap merchant.
PostPosted: Sun Mar 13, 2011 1:29 pm Up
Ahhhh never mind then Laughing
Bin bin times
