Latest: tebas93089
Overall: 17179
Online Now [95]:
Visitors: 94
Today: 6464
Total: 138108514
Forums › The Car › 206 Problems › power drain on start...
nakednakeddave
PostPosted: Thu Mar 17, 2011 11:38 am Up
so iv jus spent a few months rebuilding my engine and put it all back together and it wont start
its tries to turn over but is just draining all the power,
jumped it off another car and was draining power from that aswell....
checked wiring and seems fine, gave the earths a bit of a clean and its still the same.
any ideas what it could be?
naked
fat exhaust, dodgy rusty bonnet, stickers and steels....
KRU KREW
Danny.
PostPosted: Thu Mar 17, 2011 11:42 am Up
Did you change the ECU?
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
MrrNoName
PostPosted: Thu Mar 17, 2011 11:52 am Up
does it turn over, or try but wont actually crank, if it wont crank its probs timing way way out
nakednakeddave
PostPosted: Thu Mar 17, 2011 1:02 pm Up
ECU's the same and the timing spot on....
it cranks but wont go fast enough to actually run
like i said, its like the starter is taking heeeeaps of power but not being able to do anyhing with it....
KRU KREW
Ash
PostPosted: Thu Mar 17, 2011 1:05 pm Up
Tried rolling/bump start?
nakednakeddave
PostPosted: Thu Mar 17, 2011 1:07 pm Up
nope, because the b atterys dead and has to be jumped.....
KRU KREW
Ben.M
PostPosted: Thu Mar 17, 2011 1:13 pm Up
Try a different battery Razz
Ben.M
PostPosted: Thu Mar 17, 2011 2:14 pm Up
have you checked the Timing belt sequence??it's very important for the engine to start,sometimes if it's fitted in the wrong way,it makes the throttle body push air instead of sucking it inside the engine.
MrrNoName
PostPosted: Thu Mar 17, 2011 2:16 pm Up
bad starter motor me recons, or seized water pump, something like that preventing it from cranking
PostPosted: Thu Mar 17, 2011 3:00 pm Up
nope.
bump start can be use even when the battery and start motor is died.
unless yours is automatic.... Laughing
Ash
PostPosted: Thu Mar 17, 2011 3:30 pm Up
nope.
I was gonna say that. You just need a working alternator.
nakednakeddave
PostPosted: Fri Mar 18, 2011 11:47 am Up
waterpumps fine, timing belt and sequence is spot on....
everythings fine but starting....
iv checked and checked and checked, but might try rolling start if i can find someone to drag me up the top of my driveway...
KRU KREW
MrrNoName
PostPosted: Fri Mar 18, 2011 5:28 pm Up
is it cranking over freely or not?
PostPosted: Sat Mar 19, 2011 9:29 pm Up
nope.
nope.
No way will alternator give enough juice with a few turns from the bump start to get the show running.
