Online Now [1433]:
Visitors: 1432
Today: 175835
Total: 149245659
Forums › The Car › 206 Problems › Headlight and Horn problem
Stormcooper
PostPosted: Thu Mar 17, 2011 10:37 am Up
Hello all,
I've just bought a 53 plate GTI and the horn does not work or the N/S dipped headlight.
I have checked the obvious, fuses and changed the headlight bulb (and no did not touch the glass).
Anyone got any ideas???
206 GTI
PostPosted: Thu Mar 17, 2011 10:42 am Up
probably want to get a multimeter on the connection for the bulb just to double check its getting power?
PostPosted: Thu Mar 17, 2011 10:44 am Up
Faulty Com2000?
Stormcooper
PostPosted: Thu Mar 17, 2011 12:57 pm Up
I take it the horn and the lights connect through the com2000? Girlfriends son has a 99 1.1 so I will see if it is the same and swap to test!!
206 GTI
PostPosted: Thu Mar 17, 2011 1:00 pm Up
a 99 206 wont have a coms2000
Stormcooper
PostPosted: Thu Mar 17, 2011 1:08 pm Up
any ideas how to test? it seems reasonable that could be it, but it is only the N/S dipped beam thats not working, the O/S is ok
206 GTI
PostPosted: Thu Mar 17, 2011 1:35 pm Up
Like DJ said, a multimeter
