Latest: ArtistKS
Overall: 17145
Online Now [304]:
Visitors: 303
Today: 21256
Total: 115921041
Forums › The Car › 206 Problems › sticking revs
sticking revs
Rusky
PostPosted: Sat Mar 19, 2011 9:30 pm Up
Sometimes when I pull up at junctions and when I stop and put into park the revs stick if I dab the gas pedal they stick higher
im liking this little toy
PostPosted: Sat Mar 19, 2011 9:34 pm Up
What model?
You say park, is it auto?
Could be a sticky actuator cable or pedal or floor-mat pushing it down. (wait, wrong forum.)
MrrNoName
PostPosted: Sun Mar 20, 2011 2:37 am Up
i had this exact same problem with a fiesta, code came up with throttle position sensor reading out of range, but I changed it and the car was exactly the same.
with the fiesta, I found that resetting the ECU (by unplugging the battery) made the problem go away for a week. then it came back lol
I also found that If i unplugged that TPS the car ran rough but the problem went away completly.
unfortunatly I never found the source of the problem and the car was written off. Its something to do with the reading of the TPS though, so investigate around that area.
hope you get it sorted because I know how super annoying that can be lol.
Rusky
PostPosted: Sun Mar 20, 2011 4:16 am Up
Shes a 99 1.4 ox auto 5 door
D4NTP
PostPosted: Sun Mar 20, 2011 4:48 am Up
first thing i'd do is check the butterfly valve moves freely when operated from the throttle body.
D4NTP
PostPosted: Sun Mar 20, 2011 4:51 am Up
although with it being an auto that throws in other problems.
