Latest: Beduff1977
Overall: 17134
Online Now [684]:
Visitors: 683
Today: 77961
Total: 107067930
Forums › The Car › 206 Problems › Few queston.. ABS, ppt30, airbag.....
PostPosted: Sun Mar 20, 2011 12:39 pm Up
just a few question regarding a v reg XS
currently the abs light is on, the breaks are faulty and need changing, will this be the reason? also were is the abs bit located in engine? i though it was behind the ns light but there's only a plug there??
airbag light is flashing, the drivers has a broken wire so i take it thats probably the fault, but the passenger has no air bag, there is a thing that looks like the air bag but its empty (also has no air bag writing on it like one out my old car) also has no passenger air bag control on the right hand pannel.
ppt30 i did the fix as light wasnt working, but only displays this......
is it just a replace job or is there a fix,
thanks ben Very Happy
PostPosted: Sun Mar 20, 2011 12:47 pm Up
The ABS ECU should be behind the passengers headlamp. Maybe he removed it?
If there is no 'Airbag' or 'SRS' stamped in the dash then there is no airbag there. Does it have the de-activator switch? If no, then it will be the drivers at fault.
Needs replacing, unless you can find somewhere that sells the replacement crystal gel thats in the MFD screen
PostPosted: Sun Mar 20, 2011 12:50 pm Up
I dont think XS models came with ABS! Mine did have the wire hanging there as you speak of too though.
PostPosted: Sun Mar 20, 2011 12:51 pm Up
nice one lee Thumb Up thanks
one more thing, not having a abs ecu be a problem or is it fine to use?
PostPosted: Sun Mar 20, 2011 12:52 pm Up
the lights on solid thats what made me confused Laughing
PostPosted: Sun Mar 20, 2011 12:54 pm Up
What's the VIN, I'll look it up?
Nah it doesn't cause any problems you just don't have ABS Laughing
If I come to the Fast Show, I could always turn the ECU off in the BSI and engine so that the light would go off.
PostPosted: Sun Mar 20, 2011 12:56 pm Up
Could always just take the bulb out Wink
VIN needs checking to see if the car should have ABS fitted first though else you will get in bother come mot time.
vin vf32cnfze40638611
yer can do Very Happy
PostPosted: Sun Mar 20, 2011 12:57 pm Up
Of all the people to say that Razz
Bodge Job Razz
i was thinking doing that Razz lol
You need to fix the broken wire for the drivers airbag, hopefully the light will go out then.
PostPosted: Sun Mar 20, 2011 12:58 pm Up
Bodge Job Razz
I did say check the VIN to see if it should have ABS Wink
Just thought, whats the battery condition like?
Mine doesn't have ABS, but when the battery was f****d on mine, it lit up on the dash
PostPosted: Sun Mar 20, 2011 12:59 pm Up
No ABS as standard
I remember the ESP warning light coming on when my battery was on the way out, my car doesnt even have ESP fitted Laughing
