Latest: tbafonso
Overall: 17130
Online Now [52]:
Visitors: 51
Today: 12326
Total: 103942738
Forums › The Car › 206 Problems › Help asap!!
Help asap!!
GT1330
PostPosted: Mon Mar 21, 2011 2:57 am Up
Ok well i have a 2000 Grand Tourisme and everything was fine till this morning at 6am.Was out yesterday in car and done about 140miles+ with no problems but today i start car and its running lumpy???? sounds a bit like a scooby lol engine rocks when i start it and let it idle? hope this is an easy fix.Can anyone shed some light?
If in doudt FLAT OUT ALL THE WAY!!!!
Abzynthe
PostPosted: Mon Mar 21, 2011 3:03 am Up
East Area Rep - Abzynthe
Sounds like a misfire. Check the spark plugs, gaskets etc. That would be the first thing Smile
GT1330
PostPosted: Mon Mar 21, 2011 3:05 am Up
What gaskets do i check?
panason1c
PostPosted: Mon Mar 21, 2011 4:20 am Up
Probably dampness on the HT (high tension) electrics causing the misfire, should be ok once fully warmed up and dried out.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
Gems
PostPosted: Mon Mar 21, 2011 4:35 am Up
South East Area Rep - Gems
This happened to me and i needed a new coil pack......... but could be loads of things tbh
GT1330
PostPosted: Mon Mar 21, 2011 4:37 am Up
Great hope it aint the coilpack checked plugs and probably best replace,she due a service at 80k so just do this at same time even tho just on 78k
PostPosted: Mon Mar 21, 2011 4:39 am Up
Only use Bosch spark plugs...
GT1330
PostPosted: Mon Mar 21, 2011 4:43 am Up
Ok will do the ones i have taken out are peugeot ones as it has been serviced by them since new.
can i ask why to use bosch plugs??
PostPosted: Mon Mar 21, 2011 4:49 am Up
Peugeot ones will generally be Bosch.
Other brands have been know to make the coilpack have dicky fits. There was even a service bulletin published about not using NGK
GT1330
PostPosted: Mon Mar 21, 2011 9:46 am Up
ok well new plugs in and still the same?Take it'll be coilpack now???
Abzynthe
PostPosted: Mon Mar 21, 2011 10:40 am Up
No reason not to try it, its the next cheapest option Smile
GT1330
PostPosted: Mon Mar 21, 2011 5:34 pm Up
Better fix it or its gone
GT1330
PostPosted: Mon Mar 21, 2011 5:37 pm Up
What else can it be? i mean been running great till this morning.Need car to get to work and had to take time off till i fix it(really see why alot of people dont like french cars)
No warning of any problems parked it up and was running fine,sits all nite and now it aint???
PostPosted: Mon Mar 21, 2011 5:38 pm Up
have you got the service bulletin somehwere?
D4NTP
PostPosted: Mon Mar 21, 2011 5:49 pm Up
If you need the car sorted quickly take it to a garage, unless your pretty knowledgable you could end up spending a fair amount of cash changing things and not solve the problem and having to take it to one anyway. Coming on here and guessing (like most people, myself included do) is fine if your not relying on the car but you sound like you really need it. The information given on here is great but hardly comparable to a mechanic that can see, hear and touch the car...
