Online Now [120]:
Visitors: 119
Today: 49760
Total: 138618100
Forums › The Car › 206 Talk › Clutch - Adjustable?
Twincam007
PostPosted: Tue Mar 22, 2011 9:00 am Up
Hi
Does anyone know if the clutch can be adjusted on a 1999 206 gti 138.Reason I ask is that the biting point seems much higher than what it was previously.It almost at the end of the clutch travel.It also seem to judder a bit when releasing the clutch.
Twincam007
MrrNoName
PostPosted: Tue Mar 22, 2011 9:04 am Up
clutch is at the end of its working life Razz
the judder and high pedal biting point indicates that the friction plate is almost completely worn down, sooner or later a new clutch will be needed which will put the biting point back lower again. it might get rid of the judder, it might not, some have suggested that a new flywheel is needed to get rid of clutch judder.
in answer to your question, i believe that the clutch pedal can be adjusted with a screw of some sorts on the pedal, this was being discussed in a thread just the other day. im sure another member will verify this soon.
Twincam007
PostPosted: Tue Mar 22, 2011 10:30 am Up
Oh No...doesn't sound good.I had the clutch done at Mr Clutch and its only just going on 2 yrs.
Beforer anyone suggests it: It is NOT my driving Smile
Any idea what it costs nowadays to get the clutch and flywheel replaced andany preferences to what brand of clutch I should use?
Twincam007
MrrNoName
PostPosted: Tue Mar 22, 2011 10:48 am Up
how many miles have you done on the clutch, 2 years is pretty quick for it to wear if its NOT your driving lol. but thats really the only reason why the pedal would get higher over time
