Latest: Beduff1977
Overall: 17134
Online Now [2053]:
Visitors: 2052
Today: 150920
Total: 109717486
Forums › The Car › 206 Talk › Crystals
Crystals
Ben.M
PostPosted: Thu Mar 24, 2011 11:55 am Up
I currently have frosted headlights and really want some crystals...that was until I saw this,
206info.co.uk/Forums/v...art=0.html
Is there anyway better way to do this??? I am normally fine with electrics but this just baffles me and I dont know if I have the right connectors etc. :/
Ben.M
PostPosted: Thu Mar 24, 2011 11:56 am Up
Pay someone else to make up the loom.
Danw_VVT
PostPosted: Thu Mar 24, 2011 11:57 am Up
What She Said
Ben.M
PostPosted: Thu Mar 24, 2011 11:59 am Up
Danw_VVT wrote:
What She Said
Are they the £20-25 ones(normally)???
Ben.M
PostPosted: Thu Mar 24, 2011 12:01 pm Up
Just get the setting in the BSI changed to double optics and buy the H7 plugs from PEugeot for about a tenner
Ben.M
PostPosted: Thu Mar 24, 2011 12:03 pm Up
That sounds easier Smile
You know what im going to ask..........................how do I do that??? Razz
Ben.M
PostPosted: Thu Mar 24, 2011 12:06 pm Up
You going to the fast show?
Or if you dont want to buy the h7 plugs and wire them in the car then i could possibly sell adapters for £20posted. Not a biggy as you could easily sell on if you put your car back to standard.
Ben.M
PostPosted: Thu Mar 24, 2011 12:12 pm Up
Unfortunatly no Sad
DJ-, I'm considering that pretty much the last resort at the moment but if nothing else can be done than I may be in touch with you Razz
Ben.M
PostPosted: Thu Mar 24, 2011 12:17 pm Up
To turn it on in the BSI, you need someone with Peugeot Planet Office then just tweet the settings.
Shame because I'd have done it you for a fiver if you were going there.
Ben.M
PostPosted: Thu Mar 24, 2011 12:20 pm Up
Thanks anyway Lee, I have a bid on a set of crystals on ebay now, i'll see what they go for then it looks like i'll have to make a decision on what im going to do,
Ben.M
MrrNoName
PostPosted: Thu Mar 24, 2011 12:42 pm Up
wiring in the relay sounds way more complicated then it is tbh, if you take a step back and look at it, all you have to do is connect one wire to the battery, one wire to the earth, one wire to the mainbeam feed and one to the dipped beam feed on both sides Smile
esentially this happens:
you flick to main beam, this clicks to relay to on, power is then drawn through the relay from the connection to the battery, and goes to the dipped beam. this gives you dipped and main at the same time
when you flick back to dipped, the relay looses its input (from main beam) so clicks off, stopping the power to dipped from the relay)
it took me ages to get my head around it, but its not that bad Smile
Ben.M
PostPosted: Thu Mar 24, 2011 12:46 pm Up
Hmmm, that does actually make sense :D, I think its the diagrams that I struggle to understand really, what else do I need apart from the relay???
Thanks,
Ben.M
PostPosted: Thu Mar 24, 2011 1:20 pm Up
Bit of cable, fuse, connectors,
Ben.M
PostPosted: Thu Mar 24, 2011 1:42 pm Up
Great, thanks Very Happy
Ben.M
