Latest: Beduff1977
Overall: 17134
Online Now [989]:
Visitors: 988
Today: 118107
Total: 109684779
Forums › The Car › 206 Problems › electrical expertise needed!
robdob
PostPosted: Sat Mar 26, 2011 9:30 am Up
basically i got some new h7 headlights as replacements for my h4 headlights. i bought a h4 to h7 adapter setup, including a relay and a 20amp fuse. basically my problem is when i flick on the high beam everythings alright. but when i flick them off it blows fuses 31 and 32 which are for low beam... any ideas people? need help asap please Smile
PostPosted: Sat Mar 26, 2011 10:02 am Up
Sounds like the adapter is wired up wrong.
Remove the relay in it, and see if the fuses blow still
robdob
PostPosted: Sat Mar 26, 2011 10:49 am Up
Removed and the fuses didn't blow... Leave relay out??
PostPosted: Sat Mar 26, 2011 11:00 am Up
It means you've wired the relay up wrong Wink
robdob
PostPosted: Sat Mar 26, 2011 1:03 pm Up
As it came mate, do I really need it??
PostPosted: Sat Mar 26, 2011 1:09 pm Up
If you want the dipped beam to stay on when the main beam is, then yes
robdob
PostPosted: Sat Mar 26, 2011 1:35 pm Up
Nah tbh as long as it works I'm happy Smile
PostPosted: Sat Mar 26, 2011 1:37 pm Up
MOT failure if its not working Wink
You dont need adaptors with a relay to go from H4 to H7 on a 206 anymore, that problem is solved much easier Wink
robdob
PostPosted: Sat Mar 26, 2011 2:09 pm Up
Mot is next year now so not fussed Smile
PostPosted: Sat Mar 26, 2011 2:19 pm Up
Until you drive down an unlit country road & go for main beam Wink
total waste of timing fitting crystals if you cant be bothered to wire them up correctly Rolling Eyes
robdob
PostPosted: Sat Mar 26, 2011 4:07 pm Up
welli tried wiring up the relay differently and no luck Sad
PostPosted: Sat Mar 26, 2011 4:56 pm Up
can you not just fit the new light stalk?
PostPosted: Sat Mar 26, 2011 5:01 pm Up
i agree
just leave the relay out and do this if you still having trouble.
robdob
PostPosted: Sat Mar 26, 2011 5:12 pm Up
where cam i get one cheap?? and how would i fit it??
PostPosted: Sat Mar 26, 2011 5:37 pm Up
206info.co.uk/Forums/v...t=lee.html
