Posted: Sat Mar 26, 2011 6:03 pm |
manage to loose the torsion bars on the disc axle (finally)
just wonder which way/ direction should i take out the whole torsion bar? (if you know what i mean lol)
Posted: Sat Mar 26, 2011 6:06 pm |
From the passengers side you knock out the drivers (bottom one)
Knock from the drivers to the passengers (top one)
Off set washers out?
Also they can knock out either way, you just cant take them out doing the opposite way to the above
| Team Impossible Possible
Posted: Sat Mar 26, 2011 6:07 pm |
narr , just so the splines aint catching.
just make sure to clean the splines on the bar and where it fits and get some copper grease on there and if its needs to be adjusted again it takes 15 min
Posted: Sat Mar 26, 2011 6:08 pm |
Addaz wrote: |
Also they can knock out either way, you just cant take them out doing the opposite way to the above |
nono
i have already knock out the torsion bars,
i just need to remove the bars from the axle completely
Posted: Sat Mar 26, 2011 6:09 pm |
Top part of my message then mate
Posted: Sat Mar 26, 2011 6:11 pm |
simple pics lol +-----+ is the torsion bar, | is the trailing arm
right arm|+---------+| left arm (before)
right arm +---|---+| left arm (now)
which way should i take out the torsion bars?
Posted: Sat Mar 26, 2011 6:12 pm |
Addaz wrote: |
Top part of my message then mate |
so that means i just keep knocking them in the same diection?
would it not damage the thread? as left and right is different?
because i remember when macj fit my torsion bar he install the bar from the middle.....
they should just slide out the way you have knocked them.
clean the end up before tryin to get them out.
Posted: Sat Mar 26, 2011 6:13 pm |
Seabook wrote: |
Addaz wrote: |
so that means i just keep knocking them in the same diection? |
Yup
Posted: Sat Mar 26, 2011 6:19 pm |
ok thz, anyway can't do it now....
have to wait until morning lol
Posted: Sat Mar 26, 2011 6:23 pm |
Left to right is different
As it only fits one way, coming out of the axle, one end is bigger
I found this out when i stripped down my axel
Top tortion bar
+++|++++ | (drivers side)
Lower tortion bar
| ++++|+++ (drivers side)
Posted: Sat Mar 26, 2011 6:27 pm |
Addaz wrote: |
Top tortion bar
Lower tortion bar
| ++++|+++ (drivers side) |
nice one addaz, i know what to do now
Posted: Sun Mar 27, 2011 3:24 am |
haha
Posted: Sun Mar 27, 2011 3:30 am |
