Latest: S2cgm
Overall: 17178
Online Now [165]:
Visitors: 165
Today: 38066
Total: 137045630
Forums › The Car › 206 Problems › Suspension strut clamp
jamie_206
PostPosted: Sat Mar 12, 2011 11:18 am Up
Help! Lol im stuck changing my struts . The clamp that holds it in wont let go ive got the nut off but the bolt wont come out . Has any one had this or got an idea?
richpowell91
PostPosted: Sat Mar 12, 2011 11:23 am Up
Have you tried knocking the bolt back through, with the nut screwed on a little to protect the threads? You can also try and use a chisel and drive it into the gap at the back to open it up so that the strut isnt being held in the top of the hub?
PostPosted: Sat Mar 12, 2011 11:25 am Up
you mean the ball joint bolts?
just tap it out
jamie_206
PostPosted: Sat Mar 12, 2011 11:32 am Up
Yea ive hammerd it and it wont budge . As for using a chisel I can get it in but cant really do anything with it due to having no room back there :s
richpowell91
PostPosted: Sat Mar 12, 2011 11:38 am Up
Bigger hammer is the answer Razz
To get more room to hit the chisel try and turn the hub to full lock so the back of the hub is closer to the front, so you get more room to use the hammer.
jamie_206
just tap it out
No mate the clamp that holds the shock absorber to the hub
jamie_206
PostPosted: Sat Mar 12, 2011 11:44 am Up
Good advice il give it a go !
PostPosted: Sat Mar 12, 2011 12:51 pm Up
As suggested, just try a bigger hammer. I t will have been in there a few years but it will come out with a good smack from a heavy hammer. I hope you've bought some new ones to replaced the old stuff?
jamie_206
PostPosted: Sat Mar 12, 2011 2:39 pm Up
It didnt work ! Sad only replaced them last year didnt think they would be so jammed! And yea I got all new bits .
PostPosted: Sat Mar 12, 2011 2:50 pm Up
Did you use copper grease on them?
jamie_206
PostPosted: Sat Mar 12, 2011 6:52 pm Up
Yea I think so . It seems like the clamp is pinching the bolt . I got the strut out by about 1cm but it wouldnt come any more .
dalton-gti-180
PostPosted: Tue Mar 29, 2011 12:44 pm Up
just changed the 180 suspension to coilovers getting old ones out were a pig but i took trackrod off and spring clamps helped a treat then u just pull the hub and turn it and just keep f*****g around and it will come out Smile
your defeat now is your victory in the future
PostPosted: Tue Mar 29, 2011 12:54 pm Up
Did you take the hub off the wishbone first?
