Posted: Tue Mar 29, 2011 3:26 am |
Hi,
I have read all the posts about painting the Brake disc's covers and drums but i was wondering... i have a tin of hammerite paint can i use that on the drums and disc covers ? or do i need to buy another type of paint ?
I have read post on the tinternet too and they all seem to think it works fine if not better then other paints
cheers
Jamie
Posted: Tue Mar 29, 2011 3:36 am |
Thats what I always use n it works fine bud
| 1999 1.6 v8 ripspeed front door speckers, jbl back door speskers, vibe slick 6x9s. gti steering wheel, momo gear knob, debadged, after market bonnet vents, m3 mirrors with leds and info sticker | |
Posted: Tue Mar 29, 2011 3:40 am |
hammerite is fine to use. just mask the discs etc up well if your not taking the calipers etc off .
Posted: Tue Mar 29, 2011 3:44 am |
excellent ! time to get painting i think im going to do this in the bank holiday after my holiday to benidorm lol so i'll post up some pix on the finishede product cheers
Posted: Tue Mar 29, 2011 3:57 am |
| Danw_VVT wrote: |
| hammerite is fine to use. just mask the discs etc up well if your not taking the calipers etc off . |
yeh what Dan said.....i ended up painting pipes and clips haha
Posted: Tue Mar 29, 2011 4:01 am |
| kingdom200 wrote: |
| Danw_VVT wrote: |
yeh what Dan said.....i ended up painting pipes and clips haha |
thats a point what pipes can you paint using hammerite ?
Posted: Tue Mar 29, 2011 4:04 am |
I did mine 2.5 years ago when I still had alloys on. WHEN the car's clean, the finish is still brilliant.
Hammerite ftw.
| Hi Mikey
i wouldnt paint any pipes mate, certainly not rubber ones like brake hoses etc, they would probably flake aswell.
Posted: Tue Mar 29, 2011 4:13 am |
ok one more question how do i remove the calipers ? *or is there a post on here any ones knows of ? * or is it just easier just leave them on ?
Cheers
Posted: Tue Mar 29, 2011 4:14 am |
I didn't even take them off tbh with you.
| Hi Mikey
Posted: Tue Mar 29, 2011 4:18 am |
Posted: Tue Mar 29, 2011 4:44 am |
Posted: Tue Mar 29, 2011 5:03 am |
this is a bit of a neewb Question ... but whats the best way to do this .... i.e can i just jack one side of the car up at a time and do one wheel or using jack/axle stands ... if using the secound option where do the stands go ?
Posted: Tue Mar 29, 2011 5:13 am |
check your manual for jack points
this can be done 1 at a time, tip though. turn the wheesl to the right. give you better access to the bolts and rear of caliper.
