Latest: Daz682237
Overall: 17136
Online Now [169]:
Visitors: 168
Today: 96509
Total: 110955925
Forums › The Car › 206 Problems › 206 Failed on emissions today... advice?
vjohn82
PostPosted: Tue Mar 29, 2011 2:49 pm Up
Bleedin' thing failed on emissions... pics below of the results and fail sheet... any advice?
I am better at legal and financial stuff than anything mechanical... but I will give anything a go so long as I have a Haynes manual
vjohn82
Car has had a full service, new CAT and lambda sensor March 2010.
richpowell91
PostPosted: Tue Mar 29, 2011 3:04 pm Up
Has it been serviced this year?
Was the CAT a good quality one as cheap ones can fall apart and fail in a relatively short time.
Any blows in the exhaust system?
EML on?
Has it been running fine recently?
Also take the car for a good run to get it nice and hot before hand as that tends to help to get the emissions down.
namgaj
PostPosted: Tue Mar 29, 2011 3:06 pm Up
Bang some Wynns pre MOT in your petrol and go for a blast Wink
4.0 V8 S-Type Jaguar
iainlovatt
PostPosted: Tue Mar 29, 2011 3:25 pm Up
only use shell petrol premium, they have additives to bring emissions down! make sure before the MOT you have run the engine for 1/2 hr before hand...
ps mine is tomorrow and i have shell petrol in there and taking it for a drive at 730 in order for the engine to be red hot!
(My Garage)
MrrNoName
PostPosted: Tue Mar 29, 2011 3:28 pm Up
as said above mate, all that you can do really, if it still fails after all of that its probs because of the high mileage? is it a small engine?
vjohn82
PostPosted: Tue Mar 29, 2011 4:22 pm Up
I'll stick some high premium fuel in, some cleaner and thrash the life out of it... gotta be cheaper than diagnostics etc
CAT was good quality... so was lambda sensor.
Car serviced 2 weeks ago.
PostPosted: Tue Mar 29, 2011 4:31 pm Up
DIAGNOSIS
Diagnosis of high emissions can be an involved process that usually requires special tools and measuring equipment. However, armed with a test report indicating what gases are high can help you determine what systems may not be functional. If the vehicle has failed as a result of high CO and HC, the CO failure should be diagnosed first. If the "Service Engine Soon" or "Check Engine" light is on it should be diagnosed prior to any emissions diagnosis. CO Failure is the result of an excessively rich air fuel mixture. The following is a list of the most common causes:
- Defective Oxygen Sensor
- Inoperative Air Injection System (if equipped)
- Leaking or defective Fuel Injectors
- Restricted air filter (especially if high CO is present only at high RPM)
- Vacuum leaks resulting in improper MAP sensor operation
- Defective air mass or air flow sensor
- Malfunctioning fuel evaporation system or purge valve
- Defective Catalytic Converter
- Defective thermostat (cooling system), thermostat stuck open
- Oil contaminated with fuel, excessive miles between oil changes
HC Failure is the result of incomplete combustion. Any item that causes incomplete combustion can result in high HC. The most common causes are:
- Worn spark plugs
- Defective spark plug wires
- Worn distributor cap and/or rotor
- Improper ignition timing, usually over advanced
- Vacuum leaks
- Engine mechanical failure, low compression, worn valves, excessive oil consumption
NOX Failure is the result of combustion temperatures that are too high. The most common causes are:
- Inoperative Exhaust Gas Recirculation System (EGR)
- Cooling system malfunction, engine running too hot (restricted radiator, defective thermostat, etc.)
- Over advanced ignition timing
- Excessively lean air fuel mixture (defective oxygen sensor, MAP sensor or Air Mass Sensor)
www.auto-repair-help.c...ailure.php
vjohn82
PostPosted: Tue Mar 29, 2011 4:35 pm Up
Are my readings considered excessive?
ReeVo
PostPosted: Tue Mar 29, 2011 5:24 pm Up
Mine just failed on emissions 3 days ago. It was the bottom reading and he suggested lambda sensor or potentially CAT.
Sorry to hijack but whilst it's been brought up, can someone clarify if this is reasonable or is he being a cowboy?
Team: Slightly addicted to 206Info.co.uk Wink
Team: PS CS4 Razz
namgaj
PostPosted: Tue Mar 29, 2011 5:26 pm Up
I know of an unscrupoulous character that if your cars over the emmisions test, he shoves the probe up an exhaust that will pass it Rolling Eyes
PostPosted: Tue Mar 29, 2011 5:34 pm Up
or could just pay him a few cans of beer Razz
Deceitful
PostPosted: Tue Mar 29, 2011 6:11 pm Up
id take it to the dealer, £49.50 for a diagnostic read. that will more then likely give you the cause and then take the right action no point trying to fix it by p**sing in the wind and hoping for the best. who knows it could be something simple?
Peugeot 206 Zest 1.1 5 door
vjohn82
PostPosted: Wed Mar 30, 2011 1:27 am Up
The car passed on the lambda sensor though so it can't be that. It must be the CAT then... which is balls.
vjohn82
PostPosted: Wed Mar 30, 2011 1:29 am Up
If the car passed on the lambda sensor... (meaning the o2 levels were ok at that point) but the CO levels were out of whack when it reached the probe would it be reasonable to suggest that the CAT might be at fault?
