Posted: Sat Apr 02, 2011 12:45 pm |
Hi All,
Today I fitted a New front Bumper with Fog lights,my car didn't had ones before,so I fitted them today,and connected the plugs which where hooked behind the headlights,and I put a (15) fuse in the fuse box which in located in the engine bay in number (6),then I used the PP2000 to activate them,which I did,and it gave me the fog light light on the speedo,but the foglight didn't went on :(,so I wanna know what goes wrong,even though I tested the fog lights bulbs before I fit them,and they worked fine,so please help me.
Tim
Posted: Sat Apr 02, 2011 12:47 pm |
Test to see if the +12v is reaching the fogs, if it is. Then is a earthing problem.
Posted: Sat Apr 02, 2011 12:54 pm |
Lee wrote: |
Test to see if the +12v is reaching the fogs, if it is. Then is a earthing problem. |
Thank you so much for your fast reply :),will do that in the morning,because it's dark outside,it's 10:00 PM now :(,and see how it goes,I will keep you posted,thanx
So if it was an earthign problem,should I check the earthing points located under the headlights on (L+R)??
Posted: Sat Apr 02, 2011 12:55 pm |
Yeah just get the earthing points, or run new earth wires.
The earths on the fogs are pretty s**te tbh
Posted: Sat Apr 02, 2011 12:58 pm |
Think this has happened to mine. My car had working fogs before but now changed the front bumper and one side is now not working! Pain in the ass.
Posted: Sat Apr 02, 2011 1:23 pm |
Lee wrote: |
Well you didn't mention the other side of the problem,which is "What if there is no +12v feed reaching the fogs??is there is a relay that I need to check,or they don't need relay??
Posted: Sun Apr 03, 2011 4:22 am |
well I took the fogs plugs out,and I check by the voltmeter,but there is no +12v,it shows zero :(,so what can I do next??
Posted: Sun Apr 03, 2011 4:26 am |
you say you used the loom from behind the headlights? Would this not be the other headlight loom that is in most 206s for either h4/h7 connectors? And not for fogs?
| NO LONGER ACTIVE ON THE FORUM | |
Posted: Sun Apr 03, 2011 4:29 am |
2006 should have crystals as standard, so the h7 will be in use.
So the spare one should be the 2 pin, grey connector for the fogs.
Test to see if power is reaching the fuse like I said.
Could always check the amps when you turn the fogs on, to see if it changes.
Posted: Sun Apr 03, 2011 5:15 am |
Trade Rating: +32
mattievrs wrote: |
you say you used the loom from behind the headlights? Would this not be the other headlight loom that is in most 206s for either h4/h7 connectors? And not for fogs? |
This
Posted: Sun Apr 03, 2011 5:27 am |
But the looms behind the headlights couldnt reach down to the fogs could they?
Posted: Sun Apr 03, 2011 8:12 am |
mattievrs wrote: |
Lee wrote: |
Could always check the amps when you turn the fogs on, to see if it changes. |
As Lee said,I have H7 headlights,and I have the Grey plugs ready in the loom for foglights,and it's 2 Pin and fitted 100% on the fogs.
Posted: Sun Apr 03, 2011 8:14 am |
DJ- wrote: |
But the looms behind the headlights couldnt reach down to the fogs could they? |
They reached down the fogs very well,it's made for that purpose,I will post pics soon
Posted: Sun Apr 03, 2011 8:27 am |
Timon2210 wrote: |
DJ- wrote: |
They reached down the fogs very well,it's made for that purpose,I will post pics soon |
no i mean the headlight looms could surely not reach to the fogs?? well mine dont!
Posted: Sun Apr 03, 2011 8:36 am |
DJ- wrote: |
Timon2210 wrote: |
DJ- wrote: |
no i mean the headlight looms could surely not reach to the fogs?? well mine dont! |
Headlight looms are plugged into the headlamps
