Latest: tbafonso
Overall: 17130
Online Now [161]:
Visitors: 160
Today: 1542
Total: 103737367
Forums › The Car › 206 Problems › Drop links
Drop links
LilLew
PostPosted: Sun Apr 03, 2011 6:50 am Up
Hi all
i am having problem undoing my drop link bolts, so i can do my top mount bearing the bolt is just spinning and i know you can put a torxs in the end and undo it that way but it has never been changed so the rust has go to it any ideas.
2003 Pug 206 2.0 GTI 180
Harty
PostPosted: Sun Apr 03, 2011 7:01 am Up
a pair of mole grips on the rubber and it should undo then... if not then cut it off and put on a new one
Chris
Harty
Northeast206
PostPosted: Sun Apr 03, 2011 7:23 am Up
i had the same problem fittin my coil overs i just angle grinded the bolts off and got a new set for 20 pounds with bolts and they dont have those stupid torx ends
Didz
PostPosted: Sun Apr 03, 2011 7:30 am Up
mole grips on the rear matey as said above.
if your struggling with one try the other if the link hasnt gone. i presume your on the top one but the bottom would do.
Life's for living....
LilLew
PostPosted: Mon Apr 04, 2011 2:57 am Up
thanks for the replies and both bolts do it i have just gonna have fun with a hack saw i think and replace both sides
