Online Now [522]:
Visitors: 521
Today: 32745
Total: 105474776
Forums › The Car › 206 Talk › Normal Coolant temp
Normal Coolant temp
Go to page Previous  1, 2
PostPosted: Sat Oct 06, 2012 4:06 am Up
Mike_XS wrote:
carlosr23 wrote:
Mine from 90 to 100
Shouldn't really go above 90...
Should.
Low speed fan kicks-in at 96 C.
You can use this info to find-out by how much your temp-gauge is out. With the pointer damping and other factors involved it can easily be as much as 10 C out. On a long-journey the coolant temp will be 89 C because that's where the wax thermostat keeps it if it's working properly. Again, this will give you an idea if the gauge correlates.
Non-mux 206 have sepperate sensor ellement for the temp gauge and are always the worst. The coolant-temp sensor has 3 wires instead of 2 in this case, and casing is used for grounding too.
Page 2 of 2
