Posted: Fri Apr 15, 2011 1:55 pm |
Yesterday I drove my car a bit to erratically and i could smell burning clutch. The clutch stopped engaging and I was going nowhere. I managed to coast the car home. I have left it for over 12 hours now. I just tried to drive it and the clutch feels stiff, the travel seems shorter and the clutch doesn't bite. Is it a case of just leaving it for a while longer or am i going to have to get a new clutch?
Cheers for any help.
| 1.4 Quiksilver
Team: No 6x9's | |
Posted: Fri Apr 15, 2011 1:59 pm |
If its not biting you probably need a new clutch.
Posted: Fri Apr 15, 2011 2:06 pm |
It bites ever so slightly but not enough so that i can pull away. I had a new one fitted 10,000 miles ago. Not looking forward to the bill!!!
| 1.4 Quiksilver
Team: No 6x9's | |
Posted: Fri Apr 15, 2011 2:08 pm |
obviously you don't know how to use a clutch or you have fit a nasty cheap clutch
Posted: Fri Apr 15, 2011 2:18 pm |
| t_11! wrote: |
| It bites ever so slightly but not enough so that i can pull away. I had a new one fitted 10,000 miles ago. Not looking forward to the bill!!! |
Should still be under warranty.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Fri Apr 15, 2011 2:19 pm |
You defo need a new clutch, pay a bit more for a 'quality' clutch kit this time.
| 1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS | |
Posted: Fri Apr 15, 2011 3:50 pm |
Get a Sachs clutch. I got one fitted not too long ago... Loved it!
10000 times better than the one I had before!
For the little extra, it's definately worth it.
