Latest: tc.206
Overall: 17147
Online Now [382]:
Visitors: 381
Today: 15839
Total: 116435991
Forums › Tuning, Modification & Legal › Project Cars › Harry's XSI - Pic Heavy
Go to page Previous  1, 2, 3, 4, 5, 6, 7
PostPosted: Thu Jul 05, 2012 1:52 pm Up
Thanks Smile
PostPosted: Thu Jul 05, 2012 1:57 pm Up
165/40's were ermmm fun at just shy of a ton Laughing
They were brilliant in the wet being so thin, but bring the speed up past 70 and you start laying a wall
Speaking of which i have a set of 165/40/16's for sale? Wink
L5_UKS
PostPosted: Fri Jul 06, 2012 7:15 am Up
They look awesome Harry! Smile
PostPosted: Fri Jul 06, 2012 7:20 am Up
Were they the ones on 7J nimrods? On 7.5J it would be even worse Laughing
Cheers luke surprisingly much easier to keep them clean...
206gt160
PostPosted: Thu Jul 18, 2013 3:04 pm Up
your car looks spot on pal.. like everything thing about it
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
Brokebad95
PostPosted: Sun Jan 05, 2014 11:33 am Up
What were those FK Coilovers like?
PostPosted: Sun Jan 05, 2014 2:38 pm Up
Jesus bump from the past!
Unfortunately this car is no more - met mr. scrap man last summer.
Although my 2.0 HDI now looks identical minus the smoothed boot Wink
FK coilovers... well I just wound them fully down so there was no compression anyway so I don't think I'm in a position to fully criticize the ride. However I found the tolerance on the actual strut shocking. Yes it was actually larger than the hub carrier slot. I ended up having to shave it down (not the best idea but there was no other option).
This is what you get when you buy cheap. I have gone through kersh's old janspeed ones and the build quality was far far better. Maybe it was a quality control issue I'm not sure. the actual overall diameter difference between each strut was around 0.5mm or something crazy.
But apart from that, budget and give you the height you want. Don't expect anything amazing. If I were to go back to this sort of stuff I would have got something a little bit better to ensure they fitted properly because boy that was a ballache.
Oh and they rusted quite badly.. I only had them on for around 6 - 8 months.
Carlosrexx
PostPosted: Wed Feb 05, 2014 12:49 pm Up
Looking lovely mate, how low were you on just springs and campers? Looks about 60 or so mm?
PostPosted: Wed Feb 05, 2014 2:24 pm Up
Cheers bud - way more than that would say it was around 130mm at the very lowest (+ this is what the manufacturer said it would be fully wound down)
My old 1.4 was on 60mm springs and you could still get your arm in the gap.
Carlosrexx
PostPosted: Wed Feb 05, 2014 3:18 pm Up
That's what I meant, pre coilovers stage. With just springs and shocks. Looked good at that height anywho! I'm going coilovers at some point, it's gonna be a daily though so need to find the perfect height!
PostPosted: Wed Feb 05, 2014 4:09 pm Up
Ah right I wasn't sure what campers were haha.
Yes 60mm is good, I could get over 90% of speedbumps without scraping no problem. Could also get people in the back which is always nice!
Carlosrexx
PostPosted: Wed Feb 05, 2014 5:13 pm Up
Hah I meant dampers*
PezHdi
PostPosted: Thu Feb 06, 2014 6:59 pm Up
how low is the front on the 1st lot of pictures with the lenso alloys :] its a smart looking car.
EXL Pez
PostPosted: Sat Feb 08, 2014 3:30 pm Up
Thanks - (well it was Wink )
I'm not 100% sure as I adjusted it quite a lot of times and never measured. I would take an estimated guess at over 100mm, most likely 110mm.
Page 7 of 7
