Posted: Wed Apr 13, 2011 4:29 am |
meh, those bars on my first post. do they have the bushes on them?
| 2001, 206 1.4 lx first car  | |
Posted: Wed Apr 13, 2011 4:34 am |
Lewis1592 wrote: |
meh, those bars on my first post. do they have the bushes on them? |
There drop links.
The antiroll bar is another part of the front suspension & that has its own bushes.
Posted: Wed Apr 13, 2011 4:38 am |
fair enuf.. but it not the anti roll bar im replacing. its these drop links. just talk of bushes and stuff had me a little :S but ill crack on with these. and see how i get on. they were posted today.
Posted: Wed Apr 13, 2011 4:50 am |
If you had titled your thread "droplinks" it would have been so much easier
Posted: Wed Apr 13, 2011 4:55 am |
dont judge me haha i know im a noob..ten lashes for using the wrong terms.
Posted: Wed Apr 13, 2011 5:09 am |
CD-vRS wrote: |
Bushes were about £5 each from Peugeot last year.
Very simple/easy job to change them. |
Correct.
Posted: Fri Apr 15, 2011 5:12 am |
okay so these arrived this morning. i thought there should be a torx screwdriver on one side? im slightly :S
Posted: Fri Apr 15, 2011 5:16 am |
There is a flat part that you can hold with a spanner. Probably 16mm or so.
Posted: Fri Apr 15, 2011 5:19 am |
great thanks. did consider it but i wanted a 2nd opinion.
