Posted: Thu Apr 14, 2011 6:30 am |
Just went out in my lunch break and noticed my 206 was poor on acceleration. Also when i try to accelerate and when i get into 3/4000 rpm and above it starts to make a whistling sort of sound, which i notice the most when im accelerating in 4th gear..
To get an idea of the sound it makes imagine a belt spining and getting worn away? a kind of light whistling sound.
Any help would be great,
Cheers,
Liam
Posted: Thu Apr 14, 2011 6:46 am |
Does it whistle out of gear?
Posted: Thu Apr 14, 2011 6:47 am |
when its out of gear it is normal. also when i have the clutch in and accelerate it is normal and doesnt make the sounds. its only when im in gear and the clutch is up.
Cheers,
Liam
Posted: Thu Apr 14, 2011 7:18 am |
thrust bearing?
Posted: Thu Apr 14, 2011 7:28 am |
don't think its the thrust bearing as i had a whole new clutch about 2 months ago, also i thought it was the thrust bearing when its made a noise when clutch is up even when in neutral. my problem is u only start to here the squealing at about 3-4000 rpm. and its made the acceleration on the car poor. :s
Liam
