Latest: tbafonso
Overall: 17130
Online Now [327]:
Visitors: 326
Today: 4303
Total: 103452153
Forums › The Car › 206 Problems › suspension or backbox??
karimali831
PostPosted: Thu Apr 14, 2011 5:29 am Up
when there is people sitting in the back and I go over the bumps, the back box hits the bumps. I checked the back box and it does seem lower than it should, or is it? or it could obviously be the suspension or both be a factor.
so took a picture of it:
img845.imageshack.us/i...0956wd.jpg
if I was to get this serviced, I was thinking I might aswell get a new back box... any idea how much labour approx will cost on this ? to replace the back box with this:
cgi.ebay.co.uk/PEUGEOT...27a4dbdd16
if i need new suspension, will this cost a fortune ? Sad
206 GTI 180
ukskater01
PostPosted: Thu Apr 14, 2011 5:32 am Up
Your back box is way too low, could just be that it's come away from it's mounting points or that the rubbers have perished, replace the rubbers If needed and re-mount properly
Antknee
It looks lower than it should do, have you checked all the mounts?
PostPosted: Thu Apr 14, 2011 5:45 am Up
If it was suspension then it would still sit correctly in the bumber cutout. Looks like the mounting rubbers may be worn and stretched. Simple and cheap fix if they are.
There is a possibility that the metal mountings are bent, but only way to tell is to stick your head under and look at the exhaust mounting point.
Kersh
PostPosted: Thu Apr 14, 2011 6:03 am Up
why does that hit? ive seen much lower..
sure your backbox isnt hitting the underside of the car?
Member number: 36
karimali831
PostPosted: Thu Apr 14, 2011 6:22 am Up
i havent got out to check to see what it was but if you say you've seen lower which doesn't collide with bumpers then it must the suspension?
206 GTI 180
bellevuespares
PostPosted: Thu Apr 14, 2011 6:37 am Up
Do as people suggest and check your rubber mounts. your problem as nothing to do with suspension with the description and photo you have supplied
Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes!
karimali831
PostPosted: Thu Apr 14, 2011 6:39 am Up
I do not much about cars, don't know what rubber mounts are. I can take pictures under the car if this helps?
206 GTI 180
bellevuespares
PostPosted: Thu Apr 14, 2011 6:46 am Up
Look underneath a tthe rear, You will rubber mounts, Brackets that hold your exhaust in place! If these look to be stretched and perished rather than solid, then they need changing.
bellevuespares
Where you located?
bellevuespares
PostPosted: Thu Apr 14, 2011 6:50 am Up
As you mentioned replacing the rear box, I would suggest NOT buying tht one you shown, Im guessing you are a young driver? Keep it standard for best performance and reliability.
karimali831
PostPosted: Thu Apr 14, 2011 7:00 am Up
why don't you recommend? what are recommended ones?
img856.imageshack.us/i...g0957m.jpg
it looks like it has been in the ocean for hundreds of years.
206 GTI 180
Antknee
PostPosted: Thu Apr 14, 2011 7:05 am Up
My god thats rusty lol how old is the car? looks as though the rubber mount is broke, even if thats not the cause it would be worth replacing it, the rubber thing at the top of the photo between the underside of teh car and the exhaust
karimali831
PostPosted: Thu Apr 14, 2011 8:06 am Up
quite old 1999. I'm going to get new backbox anyway just want to know why the one I chosen was not recommended?
206 GTI 180
PostPosted: Thu Apr 14, 2011 9:43 am Up
Have you ever stood at the side of the road waiting for the big beefy car you heard 20 minutes ago to go past, only to find it is a Corsa crawling along, being driven by a baseball capped, spotty teenager, led almost horizontal, with foot to the floor in second gear just to make all the noise?
If you had a performance engine, then i'd say go for it.
At the end of the day it's your money so buy whatever you want. It's not my cup of tea.
