Posted: Mon Apr 11, 2011 1:32 pm |
My mechanic friend looked at my rear suspension today and said I might need a new rear axel. He's Turkish and doesn't speak very good English, from what I could understand my bushes are knackared and my axel bearings are worn aswell.
I phoned my local motor spares shop who said they didn't low what axel bearings are and said I must mean wheel bearings, is this right?
Thanks for your time
| You never really learn to swear until you learn to drive | |
Posted: Mon Apr 11, 2011 1:35 pm |
No they are different to wheel bearings.
Wheel bearings are completely different from Axle bushes/bearing
Wheel bearning is easy to do, Axle bearing/bushes is a bit complicated
I think you friend meant Axle bushes/bearing, Go and ask him again, is it wheel bearing or the axle bearing/bushes
| Looking to buy my first peugeot 206 | |
Posted: Mon Apr 11, 2011 1:37 pm |
no.
axle bearing is on the trailing arm, one outer bearing and one inner bearing, plus oil seal as well.
bush i presume you mean the 4 rubber bush between the axle membrane and the chasie.
wheel bearing are on the hubs.
phone the pug dealer and they will give you the right parts
Posted: Mon Apr 11, 2011 1:42 pm |
Thanks for the quick replies, is it an easy job to replace the bush, axel bearings and oil seals? Is there anything else worth replacing while i'm at it?
Thanks again
Posted: Mon Apr 11, 2011 1:50 pm |
not hard, but is time consuming.
do a search. there is probably more than 100 threads about rear axle in these 2 months!
Posted: Fri Apr 15, 2011 12:16 pm |
ukskater01 wrote: |
Thanks for your time |
Hi. I'm Turkish also. I can help to you for translation.
| 2005 206 RC RED
Lot's of CNC machined customs pars.  | |
Posted: Fri Apr 15, 2011 2:23 pm |
Thanks for the offer but I took it to his cousin who changed what I beleive to be the bush and tracking arm
cheers
Posted: Fri Apr 15, 2011 2:45 pm |
Seabook wrote: |
do a search. there is probably more than 100 threads about rear axle in these 2 months! |
Starting to boil my p**s the amount of times this same bloody " rear axle bearing " question gets asked on here
Posted: Sat Apr 16, 2011 1:36 am |
I wasn't sure what was exactly wrong, I did do a search but everyone jumps on the "change the whole axle" bandwagon, thanks for eveyones help
Posted: Sat Apr 16, 2011 2:47 am |
Just done a monster How To on this very job.
