Latest: morgan20
Overall: 17135
Online Now [292]:
Visitors: 291
Today: 30980
Total: 110742436
Forums › The Car › 206 Problems › New Remote Locking Fob
Go to page 1, 2, 3, 4  Next
bharrison89
PostPosted: Mon Apr 18, 2011 3:31 am Up
Hopefully some here can help me.
I’m aware there are many guides on here and elsewhere on the internet on how to "resync" a remote key.
However these guides don’t apply to my situation I don’t think.
After loosing my original remote key, I had a flat key that opened doors and started the car. I have since upgraded to a remote key that I bought off the teebay (Used). I have swapped the blade and immobiliser transponder so now I have a remote key that opens the door by the key and starts the engine.
However I cannot get the remote locking to sync. A mate has run it on lexia3 and he says the fob is sending a signal to the BSI, but the signal is not identified.
How do I get the signal to identify? Does the key need reprogramming, if so why? As I say the transponder is starting the car fine. Does the BSI need to be put into some kind of programming mode to programme a remote key?
I have been told that the remote chip inside the key is simply a frequency. There is no uniqueness to the chip. You simply need to get the car to tune into the frequency.
Not being a car techy forgive me if I sound like an absolute tool Very Happy
Black, 3 Door, Zest 2, 05 206
Jay794
PostPosted: Mon Apr 18, 2011 4:06 am Up
Ask Lee, he knows all
PostPosted: Mon Apr 18, 2011 8:11 am Up
1) Is it the correct fob for the car as there are 2 different types for multiplex 206's like yours.
2) A new / replacement remote fob needs coding to the BSI with Peugeot Planet / Lexia FIRST before it will ever work.
Get your mate to code the remote fob in correctly ( if its the right one! ) you will need the 4 digit alphanumeric access code to get the BSI in to key coding mode, blue plastic code card with a silver scratch panel, should have come with the car.
bharrison89
PostPosted: Mon Apr 18, 2011 8:28 am Up
MrBSI (my savior)
I will get him to run it through lexia. I'll have to pop down to the pug dealer to get my 4 digit code, it never came with car as i bought it used. A small charge i reckon.
I'm not 100% sure that the fob is the correct one, maybe the pug dealer could tell me the required part number? I have "73373067c".
I'll get this stuff sorted and come back to you guys.
Thanks for your help! Very Happy
PostPosted: Mon Apr 18, 2011 8:40 am Up
PM Lee on here, he can get the codes for you a hell of a lot cheaper then Peugeot can Wink
He will need you 17 digit VIN number
206info.co.uk/Forums/v...28327.html
PostPosted: Mon Apr 18, 2011 8:46 am Up
73373067c isnt a valid Peugeot / Citroen part number.
It should be one of these part numbers:
6554 YL / 6554 YQ for 206's with NO factory fitted front fog lights.
6554 YR / 6554 YV for 206's with front fog lights.
Once Lee has your VIN he can look it up on Peugeot Service Box & tell you the correct part number for your car Wink
bharrison89
PostPosted: Mon Apr 18, 2011 8:48 am Up
God, i was 5 minutes from setting off to the dealer. They want £25.00 plus VAT.
It's got fogs, so i presume its... 6554 YR or 6554 YV
I'v PM'd Lee, so i'll await his reply.
Thanks again, your help is much appreciated!
PostPosted: Mon Apr 18, 2011 8:50 am Up
He should be on later this evening.
Shame you aint nearer to him, he is a whizz with Peugeot Planet Cool
bharrison89
PostPosted: Mon Apr 18, 2011 8:56 am Up
He's a good few hours drive. I presume he's in Sheffield? Might have to suggest to the Mrs we take a weekend over there Wink
PostPosted: Mon Apr 18, 2011 9:00 am Up
6554 YR is the standard remote fob that would have come with the car originally.
6554 YV is the extended range version, must be a recent added upgrade to the parts listings.
PostPosted: Mon Apr 18, 2011 11:37 am Up
73373067c is the circuit board
Same as this one cgi.ebay.co.uk/Peugeot...1150wt_908
bharrison89
PostPosted: Mon Apr 18, 2011 11:44 am Up
Thank the lord... I have the right board Smile I'm gonna get my mate to run it through Lexia see if he can do it. Push comes to shuv ill get hold of PP and use his leads.
Thanks Lee Smile
PostPosted: Mon Apr 18, 2011 11:46 am Up
Lexia is Citroen not Peugeot.
I was in Blackpool at the weekend, could have done it for you
bharrison89
PostPosted: Mon Apr 18, 2011 12:03 pm Up
Nooooooooooo........ What were the chances of that! O well, ill get my mate to give it ago.
He managed to get Lexia to read the BSI ect. by telling Lexia my 206 was a C2. Maybe not the best way of doing things.... Razz
Ill get a copy of PP and let him do it that way.
Any plans to be over in B-Town again?
PostPosted: Mon Apr 18, 2011 12:05 pm Up
I know the com2000 unit on a C2 is wired up differently to a 206 Wink
Sounds like it really needs planet to read it correctly.
Page 1 of 4
