Online Now [726]:
Visitors: 725
Today: 102451
Total: 145785807
Forums › The Car › 206 Problems › clutch issue.. now will not start
lesalanos
PostPosted: Mon Apr 18, 2011 5:18 pm Up
Hi Guys,
Hoping you can help me
Since Saturday my clutch has been squealing when the pedal is touched.. looking through this might be the release bearing??
anyway whilst driving along today the car was "losing power" when driving and then 1/2 mile along the road stalled.
It now will not start. When turning the key it turns over and I can hear a "ticking sound" as though some electrics are not working. Also there is no power to the climate control panel.
Are these all likely to be linked to the initial clutch issue or is something else likely to be wrong?
The car is a 2000 X reg 2.0 HDi
The cam belt was changed 10,000 miles ago.
thanks in advance for any help
206 2.0HDi 2000 X
vanman_foci
PostPosted: Mon Apr 18, 2011 5:19 pm Up
flat battery lol
MrZiggerz
PostPosted: Mon Apr 18, 2011 5:26 pm Up
Climate control doesn't turn on until the car is turned on and running. - Well at least in mine.
cartoonhead
PostPosted: Mon Apr 18, 2011 5:46 pm Up
chances are your clutch thrust bearing has colapsed and one of the ball brearings has wrecked the head of the flywheel sensor.
It did this on mine Very Happy
the sensor you need to check is straight on top of the gear box , think its held in place by a 10mm bolt , get it out and see if there's any damage to the end of it.
eddrj
PostPosted: Tue Apr 19, 2011 12:48 am Up
mine did this clutch went and wouldnt start was the sensor cost about £330 total
Old car 2000/ 206 2.0 hdi.
lesalanos
PostPosted: Tue Apr 19, 2011 12:54 am Up
cheers guys... will have a look
206 2.0HDi 2000 X
panason1c
PostPosted: Tue Apr 19, 2011 1:06 am Up
Regarding the electrics/non-starting problem, would check the gearbox to chassis earth strap first. The squeeling is defo the clutch release bearing failure.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
lesalanos
PostPosted: Fri Apr 22, 2011 5:46 am Up
cheers for the advice guys.. it was the flywheel sensor that was stopping it running. £350 for the clutch replaced and the sensor
206 2.0HDi 2000 X
