Latest: Stu-mill
Overall: 17131
Online Now [527]:
Visitors: 526
Today: 6003
Total: 104691654
Forums › The Car › 206 Problems › 180 cambelt
180 cambelt
SAB206
PostPosted: Tue Apr 19, 2011 6:35 am Up
I just had cambelt and water pump done on 180 at local garage today.
I got it back, but the exhaust sounds louder, and the car seems a bit slower.
he said the pins lined up in the cams etc??
do you know what they could have done wrong? :/
help!
www.sab-graphics.com
I AM SYDLEXIC!
Big_Rich180
PostPosted: Tue Apr 19, 2011 6:49 am Up
Probably not used the incorrect locking tools and its been timed badly.
EDIT: or maybe the exhaust could have become loose when they had the engine off the mount, might be worth going round the exhaust joins and tightening them up.
NICKST
PostPosted: Tue Apr 19, 2011 9:19 am Up
My exhaust sounded louder after haveing mine done last month. But doesn't seem down on power.
Antknee
PostPosted: Tue Apr 19, 2011 9:29 am Up
My hdi seems louder and up on power now, im loving it lol
imjeeves
PostPosted: Tue Apr 19, 2011 9:58 am Up
That doesnt sound too good.
Having just done the belt on my 180 rally car I realise how important it is to time the belt correctly.
Is it when you rev the car or all the time?
They may well have locked the cams correcly however If they didnt use the correct crankshaft locking tool then perhaps the belt is a tooth out and when you accelerate the valves are touching.
It could just be something minimal like the exhaust loose however I would check with them and make sure the locked the floating crankshaft with the correct tool.
Ask them how the locked it!
SAB206
PostPosted: Tue Apr 19, 2011 10:00 am Up
cheers imjeeves! what tool should they have used for the crank?
I AM SYDLEXIC!
|SGP|
PostPosted: Tue Apr 19, 2011 10:36 am Up
Out of interest how much is this, and what's the rec. Time to do it? I'm not sure mines been done Sad
And will all pug garages know how to do it properly? Lol
View my car
imjeeves
PostPosted: Tue Apr 19, 2011 11:19 am Up
There is a tool looks like a cone with a point out of the end. It gets inserted into the block at the back of the engine above the driveshaft and locates the flywheel. Any other way of locking it will risk the wrong timing if the crank moves.
It takes a long time to do it. I recon flat out working on it 4-5 hours. Think its about £400-500 to get it done. No not all Pug garages will. I know for a fact my local one doesnt have the tool and just hope 180's dont come in.
SAB206
PostPosted: Tue Apr 19, 2011 12:23 pm Up
if i got hold of that tool, do you reckon i can rectify mine, or do you think its messed up now its been done wrong once?
I AM SYDLEXIC!
PostPosted: Tue Apr 19, 2011 12:49 pm Up
you will have to do the timing probably.
the tools is just to "lock" the timing (provide the timing before is good)
SAB206
PostPosted: Wed Apr 20, 2011 10:21 am Up
went back in today, came back, the exhaust cam was 1 tooth out.
Runs as it should now.. SWEET. Cool
I AM SYDLEXIC!
|SGP|
PostPosted: Wed Apr 20, 2011 10:35 am Up
What mileage is recommended for a 180?
View my car
Ali_H
PostPosted: Wed Apr 20, 2011 10:36 am Up
I did mine at 48000, can never be too careful.
kurtis wrote:
SAB206
PostPosted: Wed Apr 20, 2011 10:49 am Up
Just had mine done at 36k / 5yrs old.
As Ali said, can't be too careful.
I AM SYDLEXIC!
Andy180+
PostPosted: Wed Apr 20, 2011 11:54 am Up
did mine at 56k, looks like had one before too . better of doing now for a couple of hundred quid rather than the 1100 just quoted to a customer for a 1.4 scenic due to belt snapped. all 16 valves bent plus 8 valve guides cracked .
