Online Now [301]:
Visitors: 300
Today: 31079
Total: 106008190
Forums › The Car › 206 Problems › Jord: Couple of problems... FIXED
PostPosted: Thu Apr 21, 2011 6:34 am Up
1. My LED rear lights ... FIXED
2. My electric fan won't kick in... FIXED
Thanks, Jord
PostPosted: Thu Apr 21, 2011 6:35 am Up
sounds like youve maybe got a problem with either your fuses or bsi?
Sam-c had similar problems but he got his checked at a garage which turned out to be bsi, id be tempted just to take it to a garage for them to look at it
Danw_VVT
PostPosted: Thu Apr 21, 2011 6:36 am Up
your fan could be the wire as they tend to corrode and disappear lol
as for the lights where di d you get them from? are they cheap ones (no offence)
PostPosted: Thu Apr 21, 2011 6:43 am Up
Fan is likely to be a corroded wire. Wink
MrZiggerz
PostPosted: Thu Apr 21, 2011 6:44 am Up
My cables to the green relay were green dust Smile Probably that.
The LED's, could just be the wiring, maybe something touching?
Danw_VVT
PostPosted: Thu Apr 21, 2011 6:50 am Up
beat you!
PostPosted: Thu Apr 21, 2011 6:55 am Up
Nope they are genuine ecosse ones, jazzi (kencogirl) and Lodey owned them before me, no offence taken lol
Ali_H
PostPosted: Thu Apr 21, 2011 7:00 am Up
The lights could be a poor earth or a faulty loom, I had it on a set once. Could be damp or something, I just replaced the loom and they were fine.
kurtis wrote:
PostPosted: Thu Apr 21, 2011 7:04 am Up
Poor earth
Or wrong bulbs
PostPosted: Thu Apr 21, 2011 7:40 am Up
where are the fuse(s) and relay(s) for the fan then?
PostPosted: Thu Apr 21, 2011 7:41 am Up
Do you have aircon is a start?
If not its not the relays
PostPosted: Thu Apr 21, 2011 7:42 am Up
IIRC Its a bumper off job.. If your looking at the fan housing from the front its the bottom left cover. (You will knwo what I am on about when your looking at it..
PostPosted: Thu Apr 21, 2011 7:43 am Up
Its only if he has aircon mate
Otherwise its not that at fault
(non aircon have different fan setups)
PostPosted: Thu Apr 21, 2011 7:45 am Up
no i don't have aircon
PostPosted: Thu Apr 21, 2011 7:46 am Up
Do you have a large or short radiator?
